So I finally got my 350 put together and ready to start. Of which I thought was a hydraulic roller vortec engine.
I go to start it and I already know something is wrong. Sounds like no compression. Sure enough, none of the cylinders have compression.
I back off on the valve adjustment and I get compression on that cylinder. I do the the following adjustment again:
1) make sure top dead center for that cylinder
2) while rotating pushrod, tighten the nut such I feel when the rocker engages.
3) tighten another 1/2 turn.
Result: still no compression
Well I did the same thing, but this time 1/4 turn
Well I did the same thing, but this time no extra tightening
Result: compression.
I know they are roller lifters, what are the odds that I have solid lifters or am I just doing the #2 step wrong or is something else very wrong?
Any help would be appreciated.
LinkBack URL
About LinkBacks
