Holley id help!
Results 1 to 10 of 10
Holley id help!
    Senior Member jms-1's Avatar
    Feb 2009
    Alpine, ca
    Default Holley id help!
    i need some help figuring out what size carbs i have. i was told they were 750's but someone milled the choke towers off so i can't look up the numbers. what size diameter should the venturi and butterfly's be for a 750?
    Quote Originally Posted by jms-1 View Post
    1 3/8 venturi with 1 11/16 throttle blades
    LINK:GN-RACING.COM
    Feb 2009
    Alpine, ca
    Thank you GN7
    the throttle blades are all 1 11/16 . the primary venturi is 1 3/8 but the secondary's are 1 1/2 .
    Oct 2011
    The blade will have a 7 something number stamped on it. Means 750 cfm. If has 8 something number , 800-850 cfm carb. This is usually the case 99% of the time
    Thank you GN7
    I take it this is a 3310 vacuum secondary carb, not a double pumper. If it is a vac secondary, the secondary venturi is 1 7/16 not 1 1/2.
    LINK:GN-RACING.COM
    Feb 2009
    Alpine, ca
    hear are some pics to help out
ID:	138575   Click image for larger version.
ID:	138576   Click image for larger version.
    Its a 800
    LINK:GN-RACING.COM
    Feb 2009
    Alpine, ca
    ok, are they factory 800 cfm or did someone mix match them together? i'm just trying to make sure what i have.
    Oct 2011
    It's a list 4780. Factory stock.
    Feb 2009
    Alpine, ca
    Thanks for all the help!
