Done!
Results 1 to 14 of 14
Done!
    BIG MEMBER LOLYFE's Avatar
    Idaho
    Default Done!
    Well after four years finally got my engine stands done! Got tired of doing engine work on a table, and just could not find any well built reasonably priced units, decided to build my own, with features I like. Ten altogether six for me, and four four a buddy.
    Being a shop "fill in project" they took some time build, 3/16 wall tubing, cnc and water jetted parts on the head, and machined so they spin smoothly, tig and wire fed construction, nice casters 1200lbs each, threaded adjustable stop so they stay put when wrenching. Just have to add a machined stub so a drain pan can be added if needed , off to powder coat!
ID:	142600   Click image for larger version.
    Senior Member Retired Flatbottom Racer's Avatar
    Tulsa, Ok
    Very nice Tim!
    PF Intercoolers coolerman's Avatar
    May 2011
    Blaine, MN
    Quote Originally Posted by Retired Flatbottom Racer View Post
    Very nice Tim!
    Looks awesome, nice work.
    Super Moderator Infomaniac's Avatar
    Locust Grove, OK
    Looks nice.
    QE 439 Twin Turbo
    Tower Park Resort, Lodi, CA
    There's nothing like a good engine stand. I cringe every time I use a cheepo stand and the thing droops and wobbles like a damn bobble head once a BBC gets to the long block stage. Very nice job on those! They're all ready for chrome now
    Oct 2011
    Ship them out my way and we can hydro dip them to look like carbon fiber! Ultimate engine stands! this example we do on our Rollbars.
    Peoria, AZ
    Great job. We too, refuse to hang all that hard work and money on those cheapo deals and build our own.
    Senior Member shan's Avatar
    Yuma
    Nice work Tim! You must have also had a BBC do a double back flip and hit the floor.
    Quote Originally Posted by Spike Morelli View Post
    Golfers and Fishermen are third rate bullshitters, compared to lots of hot boaters....
    Quote Originally Posted by LOLYFE View Post
    Nice deal, what do you figure you have in materials per each? How much clearance did you allow for the "spin"?
    Idaho
    I figured with all materials and outside labor about 350 ish each, of that, casters 100.00 a stand, about 150.00 in steel, water jet and cnc time,(the arms are cnc'd, have radius ends ,tapped threads and the stands were machined with a step then pressed into them, then welded, bore and stub of head were also machined for nice tight fit) grade eight bolts about 15.00 a stand, Granted was building ten, so materials were less than if i built one. Not included was all the time to cut, drill, weld, powder-coat and final assembly. The spin radius can easily handle a 632 with tunnel ram, not sure with carbs yet!
    Senior Member jms-1's Avatar
    Feb 2009
    Alpine, ca
    you do very nice work, i have been thinking about building a couple of my own also and if you don't mind me asking, why you went with the 3 point instead of 4? I'm just asking, not judging
  13. #12
    Idaho
    Just personal preference I guess, easier to maneuver around and the cost of one less caster, lol!
  14. #13
    Senior Member OLD MAN ON THE LAKE's Avatar
    Phoenix
    Nice Meat Tim.
  15. #14
    Un-Obtainium Member BT-TX's Avatar
    Dec 2011
    Texas
    Looks great and heavy built. Awesome
