cam grind?
cam grind?
    Led
    Led is offline
    Senior Member Led's Avatar
    Jul 2010
    Default cam grind?
    I hurt my roller cam, i have another one to use, but I thought that i may just get this one fixed. Anyone on the boards fix them? I dont know what brand the cam is.
    Area 609 Perormance six-oh-nine's Avatar
    El Cajon, Ca.
    Depends on how bad... somtimes you can get away with a regrind. I'm not a super big fan of rewelding lobes unless it's something oddball or really expensive.
    Call Jerry at Schneider... he can figure out what profiles you have and chances are has something that is either right on or pretty darn close.
    Schneider Racing Cams
    619-297-0227
    The Bostick®
    Led
    Led is offline
    Jul 2010
    its a 700 plus roller, i would like a regrind to a lower, not odd ball or too expensive.
    El Cajon, Ca.
    Shouldn't be a problem then... You really can't change them a whole bunch as you can get thru (or really close) the heat treat if you start changing a bunch... but a few degrees and or a little bit of lift typically is not a problem with a regrind.
    Like I mentioned before.. give Jerry at Schneider a call... been using him for the last 20 years on pretty much everything I build and haven't had anything but good experince. Plus they do everything with the exception of heat treating and hobbing the dist gears in house... they grind them themselves.
    The Bostick®
