Need some quick info..
Which Head/Intake gaskets would work best on a BBC 540 Tall Block with a 14-71 Blower (8 lb boost) ???
Thanks in advance!!
Thanks in advance!!
"When you see the tree you're about to hit, it's called under steer. When you can only feel and hear it, it's called over steer."
I have a 540 BBC tall deck with a 14-71 also and I have had very good luck with the Fel-Pro blue gasket.
Are those the MLS gaskets??
NO. The MLS are black and rougly twice the money. You don't need anymore than this unless you running a compression above 9 to 1 and race gas.
This gasket can hold anything running on pump gas so long as you don't throw it into detonation.
LINK Felpro 1047 head gasket
LINK:GN-RACING.COM
I have had nothing but good luck with Cometic! That's what I'm currently running on my 565 with a 1471....6lbs on pump and 11 lbs on good fuel. I think that head studs and proper torque (after heat cycling) is more important than the brand of head gasket.
I use the SCE Copper Head gasket TITAN self sealing , not cheap but a very good gasket .
get mine from good vibrations
