spark plug gap
Results 1 to 6 of 6
spark plug gap
    Senior Member steele211's Avatar
    Nov 2008
    Kingsburg,CA
    Default spark plug gap
    Looking for where I should be gapping my plugs on an alky motor with a mag and an 8-71. 470 ci, 9.5:1, 15# of boost
    I run mine .019-.020
    Senior Member mdsheppie's Avatar
    Jun 2010
    Michigan,The State Of Confusion
    Quote Originally Posted by Michael Thomas View Post
    what he said...
    Horsepower determines how fast you hit the wall. Torque determines the size of the hole you make.
    Hudson, Wisconsin
    I've always gapped (w/mag) at .018 and cut the tips back to the centerline. You can now buy plugs (Autolite AR) pre-cut. Jocko
    Senior Member rocket98's Avatar
    Sandia Park, New Mexico, United States
    We run them at 20-22
    They older we get the faster we were
    Dec 2010
    Sapulpa ok
    .018-.019 depending on the mag. What is it and how hot ??
