Originally Posted by
Moneypit
IMO, torque in a v drive is less important than say, a jetboat, or a heavy cruiser. If properly set up, your boat should dry out fairly quickly and hopefully be skimming across the water on the "flat" part in the back... Also, one of the luxuries of the v drive is being able to change gears and props to "dial in" your usage to the engine's "happy spot" of the RPM curve... In reality, boat speed is based on prop speed, which is based on engine RPMs out the final drive ratio... If I were you, I would be very cautious about your cylinder head choice. All the camshaft planing in the world is useless if the heads won't flow... IMO, look around, find some used aftermarket, or factory 990s, that were designed to be used on the added cubic inches the 454 will give you, or the added flow the camshaft is designed for. That said, if your 396 crank is a steel factory unit, you might consider using it. With the larger 4.250/4.280/4.310 (+.030-.060), bore, and the short stroke 396 crank, (3.760 vs 4.000 454) you can build a cool 427/433/440 with plenty of torque to dry the boat out, and plenty of RPM potential to see some pretty scary speeds... Dual plane intakes seem to make a pleasure boat more forgiving in the "drive-ability" areas, but the open plane should RPM up top a little better if comparing apples to apples....IMO, there is a fine line between a "fun" boat, and a heavy "rump rump" cammed screamer.. Yes, you can have both, but it takes an awful lot of homework to achieve that "right outa the box".....If you really want to have a "fun" boat, design it as that when choosing engine parts, and start collecting additional stuff for another "monster" motor for the "need for speed" we all seem to have.... Enjoy your boat for a few years while you assemble a totally different engine. Remove the "sensible" engine and stick it under the bench, install the screamer, and if it fails you still have "old reliable" to fall back on and continue your "fun" on the water..... Believe me, there is nothing worse than having your boat in the shop, covered up, because the "big" motor ate up your boating budget, and then windowed the pan. Always plan for the worse case, and keep that back up complete, ready to go back in.....Good luck..
Ray
