Give me some recommendation for rebuilding 588 BBC from Flat tops currently to max comp you have had success without detonation, going in an I/O twin. Aluminum heads on motor.
Way to open ended question that will spark alittle conversation here.
But it has ALOT to do with the expected RPM operating range, camshaft and the exhaust system and the size of the boat, for starters.
You can get to around 10 to 1 with the flat tops by making sure the deck is close to zero. maybe remove a little from the heads. After that its a custom piston with a small dome. Not sure its worth that. IMO
Like David said, you need to be on your tune above that, and the boat better be pretty light.
LINK:GN-RACING.COM
I would say the size of the boat and consistency of your "pump gas" would be the main concerns. What you give up in power on a bit of compression might be worthwhile for safety margin.
Like the Bob said. Alot of things can make a differencs. I run as high as 10.5 on 91 octane. Run timing as high as 36 depending on the componets used.
LINK:GN-RACING.COM
GN, I did 10.6 on a 555 with head gasket thickness thinner made 10.8
WT
WFL Crew!!!
Certainly not trying to be controversial, just want a little feedback on what others have experienced with compresison and pump gas.
How about the scenario of mixing in E85 in a consistent basis for detonation preventitive or may consider some CAM 2 at say 5 gallons for every 15 gallons of premium. Interested in pushing the power level up, from curent flattop setup, have even considered running all E-85 with electronic fuel injection. A little feedback from ohters , always helps to head off problems. Thx.
LINK:GN-RACING.COM
Yes the pistons were made by Venolia and they are not flat tops they have a slight dome to them
I have a 4.625 bore
and a 4.25 stroke
so I think it more like a 571.??? ci we all call them 572's
then engine blueprint specification sheet says 10.59 compression ratio
I do not know half as much about motors as alot of people on the board, but I do keep a close eye on mine I have alot of guages to tell me what is going on all the time. I know that Im running close to the safty margin. But I belive that the motor will live for many years. I change the oil every 10 to 15 hrs and do not run the chit out of it all the time. And ALWAYS run fresh 92 fuel. At the end year I suck all the old out and put fresh fuel in the spring. I never let the fuel sit for more than 2 weeks
I would like to get to 800 N/A, I have AFR 357 CNC'd heads, solid roller, adding EFI to engines with this rebuild, which I already own 2 FAST units. I know you are slick on Cam tech and profiles CStraub, I currently use a Howards 260/270 @050 .675 .675 lift cam. Stellings headers. What compresion do you feel will get me to 800 @ 5700-6000?
Are all of these numbers static compression or dynamic?
Matt.
