496 BBC Dyno results
Page 1 of 4 1234 LastLast
Results 1 to 14 of 43
    GTO's and Jets Punisher's Avatar
    Jan 2010
    Tahlequah, Ok
    Default 496 BBC Dyno results
    My old 454 with RV cam and 8:1 compression was getting really tired and using a 2 quarts of oil every trip to the lake so I decided to freshen it up this winter. I took it out and when dissassembled it was determined it needed a new crank because the old crank was already turned .030 and it needed a bore so I checked into costs and decided to put a 4.250 stroke crank in it with a nice Speed Pro Hyper piston on the stock "Truck" rods with good bolts. I also found a nice set of 781 heads to rebuild for it. For a cam we used a Crane L-88 flat solid grind with 264/269 @.050 duration and 112 Lobe Separation. Induction is a Weiand tunnel ram with 2 650 Edelbrock AVS carbs. Compression turned out at 9.75:1 with the piston .005 out of the hole and the heads had no port work at all and retain the stock valves. We set the timing on 32 degrees total and used 91 octane pump fuel and 2 1/4" tube headers and we ran a manual water pump on it for the dyno.
    This engine is for my 77 Taylor SJ with Berkely pump.
    Any guesses as to what this budget 496 made for HP and where the peak was?
    570@5900 Built an engine sim iliar a few years ago. made 587@ 5900. Had a little more compression than yours.
    Southwest corner AR
    I will give you a little more than Tiger 604 HP 5900 RPM
    WT
    WFL Crew!!!
    Dec 2011
    Okmulgee Okla.
    well the block is GM any ways
    IS UNDER FIRE
    21' Liberator Jet NORDIC454's Avatar
    BIG D
    600@6000
    How come Nordic 454 is the only one of you that can post a HP without creating a bogus E-mail link?
    Hopefully, it won't make so much the OP wishes he had never chosen those pistons.
    LINK:GN-RACING.COM
    BIG D
    What is your estimate??
    Quote Originally Posted by NORDIC454 View Post
    before it fails a piston skirt?
    read this and you'll realize to never make guessitamations of engines you didn't assemble. I love playing Clue. But in the game of Clue, you have way more "clues" and evidence to go on.
    LINK: dyno test
    Heres what a single 4 bbl oval port pump gas 496 can make. I think the OP will be a little shy of this.
    LINK:GN-RACING.COM
    Jan 2010
    Tahlequah, Ok
    Widetrack was closest so far...
    Jan 2010
    Tahlequah, Ok
    Dang that turned out small...It was 606 HP @ 5300 RPM with 619 ft lbs of @ 5000. Stock 781 heads, factory L88 cam, 9.75:1, 496 ci, Tunnel Ram, 650 Edelbrocks, low RPM lake boat... just a cruiser and tube puller...
  13. #12
    Jan 2010
    Tahlequah, Ok
    GN7 - that dyno sheet looks much like the one from my 463 CI Pontiac engine in my 69 GTO... High points of that one were 709 HP @ 6100 and 680 Torque at 5400...
  14. #13
    Super Moderator Infomaniac's Avatar
    Locust Grove, OK
    What Dyno?
    QE 439 Twin Turbo
  15. #14
    Jan 2010
    Tahlequah, Ok
    What Dyno?
    Stuska - gotta be really close because my GTO at 3525 lbs runs 9.90's at 136 with the 709 HP and 680 torque...
