Does anyone know how far this can be bored. I have one that needs it. It is at 4.505 now. Again that number is # 14044807. Thanks. EVIL
If that is the older tall deck Bowtie, I have one at 4.630 and no problems !
Yes, that is correct, MK IV. I use on in my ProStock engine.
Never had any trouble with it.
Just did some googleing. Found the factory recomendeds max of 4.560. Thanks guys.
Looking to buy on of these engines, same numbers. Coming with a complete lot from
A mud truck racer that pasted.. what is a good price range for this engine?
It is complete with ls6 rect heads dominator carb ect... will need to be pulled down and checked.
Also what is the most ci u can make from the block?
Never forget where you come from,no matter where you are going.
I have a sonic test sheet form one of those blocks. Was a Keith Eickert 496... (4.31 bore) and the thinnest thrust surface bore thickness is .317". The average thickness is about .325 and there are a lot of places that are in the .340-.345 range, and as thick as .416". This was a pre-bowtie "marine" tall deck Mk IV.
