NA, 088, 496, Plug Recommendation?
Results 1 to 6 of 6
    Senior Member Constant840's Avatar
    Yucaipa, Ca
    Default NA, 088, 496, Plug Recommendation?
    As the title states... I am looking for a spark plug recommendation for a NA, iron headed 496.
    Currently running cold (nitrous) Autolite AR13's and know it should be warmer.
    Suggestions are appreciated.
    "Evolution has long been the target of illogical arguments that use presumption." - Marilyn vos Savant
    I think you are going to need to give alot more info, IE. what comp ratio,are you running the nitrous or not. what do run the timing at? do you run a timing retard if you are running nitrous? how much nos. what kind of dist you running msd or mag system. what fuel are you running ?
    whats going on with the plugs that you have tried and what do they look like?
    The more info you give the better a shot at getting good info back to you.
    Yucaipa, Ca
    Quote Originally Posted by havasubyou View Post
    9.3-1
    No Nitrous
    32 degrees
    MSD 6 with Pro Billet
    Pump 91
    Current plugs were hand me down from a blown 468 running a 200 shot. I can not find the plugs that were run in the 496, while it was a 454, so I do not have a baseline idea of what plug to start with.
    Oct 2011
    UR-5 ngk
    Nechako
    i wouldn't want any hotter than a 6 ngk
    Originally Posted by gn7
    My understanding is, the PH 30 is the specified high performance jet boat filter.
    Quote Originally Posted by Constant840 View Post
    Jason,, did some reading on Autolite racing plugs just now,, AR13 is only one step colder than the 23 I mentioned to you on the phone. You can probably run more than 32 degrees of timing, maybe try 34 or 36 degrees I think.
