I was all set to get the TFS Track Heat intake till I see that the port size on the 4500 flange manifold is huge
. I dont want a port mismatch. Should I just go with the Victor and port match the intake to my heads? Has anybody ran a Bigs Dominator 1050 carb? Thanks for any input. Just for reference here are the motor specs:
DOVE block .080 over
SRP pistons 11.5:1 Comp(Zero Deck)
Scat H-Beam Rods
Comp Cam 300AR-10 Solid roller(.663 lift 262
dur@.050 110 Lobe sep)
Heads Ported C8VE's with 2.19 1.76 Valves
