so close...yet so far
Page 1 of 2 12 LastLast
Results 1 to 14 of 16
    Douglas, MA
    Default so close...yet so far
    one little cracked oil fitting...1/8inch is now keeping me from the water...DAMMIT!
    Wet
    Wet is offline
    East Hampton, CT
    Where?
    Douglas, MA
    stupid oil fitting on the turbo...I think I have something to try today...we will see.
    Senior Member burbanite's Avatar
    Valencia, CA
    How did you make out?
    "I have neither the time nor the inclination to explain myself to a man who rises and sleeps under the blanket of the very freedom that I provide, then questions the manner in which I provide it."
    Douglas, MA
    I considered it a 'shake down' so when the engine was cold and didn't really want to run...I wasn't worried...when we traced some water leaks...no biggie...
    then the engine really started to even out, things were going well...so we stopped tightened some fittings...and then it wouldn't run again.
    So, I got towed back to shore by an outboard with a fisherman taking pics. Dammit.
    I think we traced down the problem to a dumping carb and gassed out plugs.
    Now...trying to figure out how to fix it.
    Wet
    Wet is offline
    East Hampton, CT
    Sticky float, needle and seats? The tow home could have jarred them lose so you might not find a culprit on the trailer.
    Douglas, MA
    Quote Originally Posted by Wet Dream View Post
    its still leaking...just one of the boosters though...wouldn't a needle and seat or float be on both boosters?
    Wet
    Wet is offline
    East Hampton, CT
    Is it leaking internally or externally?
    Douglas, MA
    internally...
    the fuel just keeps dripping from one of these:
    Valencia, CA
    Fuel pressure to high? 6.5 psi is max.
    Possibly an incorrect signal to the booster? Check for vacuum leaks anywhere.
    Douglas, MA
    Quote Originally Posted by burbanite View Post
    I am about a pound over that...I will start with that, the needle and seat, and the float adjustment.
  13. #12
    Wet
    Wet is offline
    East Hampton, CT
    That was my first guess, only because I had a similar situation. My needle was sticking open causing the fuel to pour down the carb. It stalled out the motor. Upon trying to fire it back up, the fuel that made it into the cylinders, also got sent thru the exhaust valves and into the pipes, where they managed to ignite...leaving a pair of flames 4 feet into the air. I got towed back.
  14. #13
    Douglas, MA
    nice
  15. #14
    Senior Member snake321's Avatar
    Middletown, Connecticut, United States
    float too high.
    YOU LIE!!!!!!!!!!!
    Quote Originally Posted by Ultra26 # 1 View Post
    I've been known to be a jackass a time or two.
