Pivoting Foot Rest
Results 1 to 3 of 3
Pivoting Foot Rest
    Performance Boats Advertiser
    Nov 2008
    Default Pivoting Foot Rest
    Our new footrest pivots for optimum comfort. With a footpad that measures 16” X 6” it is large enough to accept rubber inserts so your feet have plenty of grip in rough conditions. It is 4 ¾” tall from the base to the center of the pivot bar. Available in all Fusion Coat and anodized colors.
    600-03P Pivot foot rest assembly $275.00
ID:	51676   Click image for larger version.
    Senior Member River918's Avatar
    What are the dimensions of the mouting brackets? Also, is mounting hardware included?
    Nov 2008
    The mounting plate is 5.5" X 2.5". The mounting holes center to center are 4.75" X 1.75". Center to center on the mounting plates is 11.5".
    We do not supply mounting hardware because we do not know if you are going to screw the footrest in or through bolt it.
