maniflolds for my hallett 210 454 efi??
Results 1 to 9 of 9
    "BOUGHT NOT BUILT" 2FORCEFULL's Avatar
    Default maniflolds for my hallett 210 454 efi??
    looking for the shortest to fit under the hatch, do you have a measurement on the short ones you sell??
Name:	hallett battery 001.jpg
    are these the same as stock height?
    Performance Boats Advertiser
    Nov 2008
    [QUOTE=2FORCEFULL;1335894]are these the same as stock height?
    The EMI-510 set up measuring from the manifold to head bolt is about 16.25" tall. They are a little bit talller than the stock Mercury set up because the our runners are a lot longer. You will also save about 90 lbs of weight off the engine as well.
    [QUOTE=Eddie Marine;1336566]
    Quote Originally Posted by 2FORCEFULL View Post
    to the top set of bolts?? where the manifold bolts??? do the stick up above the plemin???
    do you know how much taller in inches???
    Orlando.FL
    Why don't you try them first to see if your performance will be better. Then go from there, if the performance is sizeable may be worth putting acouple bumps on the hatch.
    Quote Originally Posted by Schiada 201 View Post
    3 or 4 horse power would never be a good trade off for me,the boat is a pristine 1994 with only 128 hrs
Name:	mead 210 007.jpg
ID:	103351   Click image for larger version.
Name:	mead 210 002.jpg
    Nov 2008
    EMI Thunder is about 1" taller than the stock Merc. exhaust. Also, you will see a 10% increase in torque and horse power.
    Covina
    Dang...that's a nice boat.
