Well i just got the short block assembled for my 509 project. When its all done what do you recommend for engine break-in procedures. RPM, time, oil for first go round, change to what oil after that? Its a N/A 509 cid max 5500 rpm or so, 9.8CR Thanks, Dave
LinkBack URL
About LinkBacks
can't do the break in rules...just like Gary said run it normaly and a few short burst won't hurt. Change your oil after a couple of outings about 8 to 10 hours, if you see a small leak, don't worry it's normal after a few heat cycles though, check all your conections...(Steve will do this
) and then let it eat
. I think you will be happy, just remember clean oil and filters are alot cheper than a new engine and always do a pre boating check before each outing...finding a little problem before going out can solve a much bigger problem just a few hours later
...On another note when are you going to get a chance to come down, now that Ike and Gustof are gone
Too many opinions gets too confusing.
