Whipple 5.0/W305 efi Engines
Page 1 of 4 1234 LastLast
Results 1 to 14 of 44
    TPI
    TPI is offline
    Senior Member TPI's Avatar
    Default Whipple 5.0/W305 efi Engines
    These motors are the "hot topic" right now, so I thought I would post some pics. They are truely what I would call the wave of the future. They make power effortlessly. In fact, you have to really "TRY" to make a 540 make less than 1000 HP on pump gas, with the right set up of course. At any rate, they are very nice and super reliable to drive around. They feel NOTHING like a quad rotor set up at all. The throttle linkage is super smooth and very manageable at any speed. Here are some pics. Also, Watch for something new from TPI coming in the near future with these
    Member In Training Shock 'N' Awe's Avatar
    Need a little video of at least one of those bad boys running !!!
    TPI
    TPI is offline
    I'm working on it They are actually pretty boring to hear run, but man they sure feel good pushing the boat!
    Senior Member DEMOMAN's Avatar
    Escondido CA
    I sure would like to see John West build a 32 with these beasts. Come on somebody step up and make it happen.
    Senior Member new2cats's Avatar
    Simi Valley, CA
    Quote Originally Posted by DEMOMAN View Post
    You called???? J/K!!
    TPI
    TPI is offline
    Thats the thing, I guess they look kind of "Beasty", but they do not drive like it. The throttle is So smooth that it transfers the power through the drive at a nice even transition. I personally believe that the way these motors deliver power, is a big factor in keeping an XR based drive around, without constant failures. Also, the fuel economy is unreal,,,,,,,,,,,,compared to an 800-900+ HP motor with a different induction system.
ID:	5891   Click image for larger version.
ID:	5892   Click image for larger version.
    KAP
    KAP is offline
    32 DW X-CAT KAP's Avatar
    Casa de Cappy Diego by the Bay
    Dear Gary:
    I couldn't agree with you more about the future of supercharged induction for marine applications. The Quad Rotor is dead and the future is this axial 305/(5) Five litre, from Whipple Inc.
    As far as a compatible hull for these motors---Hmmm, I am somewhat biased but the NEW 36' Bullet would be the perfect showpiece for these motors.
    Currently, the fastest 28 foot V-Bottom combination in existence is a TPI/28 Bullet. Hence, it seems only fitting for the first customer to purchase or own a 36 Bullet to continue the tradition and put some TPI powerplants into the hull. In my opinion, this combination would be tough to beat in terms of performance bang for the buck.
    In anycase, no matter what hull a customer comes up with that base 540/305Whipple platform is hard to beat and very versatile.
    Very truly yours,
    KAP
    P.S. I look forward to seeing you at Desert Storm as well as Demoman, New2cats and many others.
    TPI
    TPI is offline
    Thanks Kap,
    But I would be surprised to see one of these in the first 36 Bullet. If I had one(a 36 Bullet), I would absolutely run two of these with #6 drives. That would be an incredible machine for sureThe motors are tunable on pump gas from 900-1100HP
    Escondido CA
    Desert Storm will be a great weekend. There will be a nice collection of TPI motors on the water. Sure would be nice to get them all together, maybe after the shootout on Sat?
    KAP
    KAP is offline
    Reply Comments:
    Well Gary if not the first one then maybe the second or third one. I believe the first one will have conservative Mercury power but then after that it's anyone's choice/idea.
    Plus, I was hoping the TPI/Bullet idea would catch on--- I happen to like a little tradition in the boating environment sorta nostalgic on my part along with wishful thinking.
    Demoman:
    It would be nice to meet up after all the events. I believe Sunday/Monday will be the best boating days with no deadlines or event timelines.
    Oh! by the way--- Adam you need to update your user cp from 525 to TPI848 .
    Very truly yours,
    KAP
    TPI
    TPI is offline
    Absolutely,
    I would love to get together with all of you guys for a picture and a cold beverage on Saturday. After the speed run of course My kids will be dieing to swim and relax somewhere. Hopefully in a place where we can watch the "fast boats" run Adam, you are going to love the new interior in the Bullet! It looks sharp!
    OK, Back to 5.0 Litre Whipples..........................
  13. #12
    TPI
    TPI is offline
    Default Comparison
    It's not often you get to see the Whipple 3.3L(200ax) at left next to the Whipple 5.0(305ax)at right. There is a substantial size difference
  14. #13
    Ultra26 # 1
    Guest
    Quote Originally Posted by TPI View Post
    Damn, the 5.0 is huge.
  15. #14
    KAP
    KAP is offline
    Dear Gary:
    Those photos tell a thousand words. What a great idea to put them side by side for comparison.
    Uh! can we see the intercooler's for each side x side. I take it the 200AX uses a standard size and the 305 uses a MOAC.
    Question(s):
    1. Does the 305 fit under a standard hatch?
    2. How much longer is the snout/pulley assembly on the 305 if your doing a conversion from a 200AX to a 305---In order for it to clear the back of the seat or engine compartment for clearance purposes? [I would guess about 3-4 inches]
    3. Last can we get those in different colors? ie... let's say racing blue?
    I'm simply saving my duckets for the future and these questions would be issues for both myself and someone whose thinking about these very same questions on a new build.
    Very truly yours,
    KAP
