I recently bought a 1995 Eliminator 250 Eagle. It has a double step hull with a delta pad in the rear. The boat has a 502 with a intercooled procharger, a bravo 1 drive with 1.50 gears and and a Imco 2" shorty lower with a 1" spacer. Full hydraulic steering with 2 rams. The prop it came with is a Bravo 1 28 that has been cupped by throttle-up. I bought the boat in the middle of winter with out test driving it. I recently got to take it out for a test drive a couple weekends ago and on the first attempt at some speed the boat started chinewalking violently at about 70-75 mph. My buddy who was riding with me idea was to power through-it. Wrong! I am lucky to be typing here today! Anyway, I called the previous owner and he advised me on how to trim the boat. It did get better but still came in at about 85. I swapped props with a buddy for the next weekend. I used his untouched bravo 1 30 pitch. I ran the boat up to 87 mph. (we had a gps with us this time) and the boat felt much better. I am still a little gun shy of the boat so I feathered off the throttle as soon as I felt the boat bobble. The boat pulled 5300 rpm with that prop and still felt as if it was accelerating hard. I would like to run the boat past 90 mph as it feels like it would but I don't want the thing to fall into a chine-walk at that speed. So I guess my question is what would be the best thing to do next? I would like to make the boat as stable as possible. Should I try removing the 1" spacer from the drive and try it again? The guy I bought the boat from said he had never ran it with the spacer removed. Supposedly the boat was built with a higher than normal X dimension in the first place. The boat also does not have trim tabs. I plan on adding them eventually? Anyway looking for help!
LinkBack URL
About LinkBacks
