Spark Plugs
Spark Plugs
    Senior Member The Violater's Avatar
    Default Spark Plugs
    1981 400 hp stock Mercruiser Motors in an old Scarab. Converting the ignition from points to Hei, need to know what plugs to buy. Not at the boat will have to get them before I go do the job.
    / The Few The Proud TheBlown
    Morgan Hill
    Quote Originally Posted by The Violater View Post
    Really need to either know what plugs are in it now, or know the head casting number.
    The plug can be long reach, extended tip, peanut, gasketed... Really too many variables to take a WAG and have it be reliable.
    Hope you get if figured out.
    GT
    GT
    I don't feel tardy Hallett Dave's Avatar
    Lancaster
    What does Mercury recommend and what's in there now?
    Im non induced and My turd leaves pretty hard as she sits.
    AC MR43T
    Thats a "marine" AC Delco plug.
    Heres your list of possible cross references:
    Possible spark plugs for AC DELCO MR43T:
    Accel 263
    Autolite 685
    Autolite 3624
    Autolite 3625
    Autolite 3265
    Autolite 145
    Autolite 3623
    Autolite 3627
    Bosch HR8AC
    Bosch HR8APY
    Champion BL9Y
    Champion RBL8-6
    Champion RV8C6
    Champion RV12C6
    Champion RBL8
    Champion RV8C
    Champion BL8
    Champion stk 35
    Denso T20RU
    Denso T20R-U
    Denso T20R-U15
    Denso stk 5038
    Denso stk 5039
    General Motors 5613438
    Motorcraft ASF4C
    Motorcraft ARF3
    Motorcraft stk 10
    NGK B6FS
    NGK BR6FS-15
    NGK 2927
    NGK YR5
    NGK 3624
    NGK 5334
    NGK BR6FS
    NGK R5673-6
    NGK 3475
    NGK YR55
    NGK 4323
    NGK stk 4323
    NGK stk 7240
    LINK:GN-RACING.COM
    Abraham Lincoln
