Cam profile/grind
Page 1 of 3 123 LastLast
Results 1 to 14 of 34
Cam profile/grind
    Senior Member Nosjunkie's Avatar
    May 2010
    Rough and Ready CA.
    Default Cam profile/grind
    I was wondering if there is a difference in a turbo cam vs. a blower cam profile/grind... or are boosted engine cams about the same?
    Quote Originally Posted by Nosjunkie View Post
    Virtually nothing in common
    LINK:GN-RACING.COM
    Abraham Lincoln
    Jun 2010
    expand on that Bob so he knows what the difference is,,,,
    Tri-Cities, TN
    Blower is mechanical and involves a parasitic loss of power, the turbo uses wasted exhaust byproduct to boost. Duration and lift must be manipulated to optimize both systems.
    Chris Straub
    Straub Technologies
    3HP is an A$$ Whooping!!! JW
    In other words they take two entirely different dart boards.
    See, that's what I know about turbos. I always thought you used the other hand to throw the dart.
    LINK:GN-RACING.COM
    Abraham Lincoln
    Naw, that's what other cam companies do...but not Chris.
    Nov 2009
    LOL who are you kidding......I've seen Chris's hands! They sure dont look like they have thrown to much of ANYTHING! Lol
    To give you a straight up answer with out the other "stuff" Yes a different grind would net you a better build! Talk to a real grinder and run it! No offense meant to anybody but if the OP is going turbo and a "button" maybe a grinder can work with him on what will work best for his combo! JMO!
    That looks like a tuners dart board. I prefer drawing from a hat, or using my dedicated Magic 8 Ball for tuning purposes.
    LINK:GN-RACING.COM
    Abraham Lincoln
    Senior Member sammyc57's Avatar
    Sep 2010
    Broken Bow,OK
    Ok, I wanna high jack this thread for a bit!, No denying crank drivin superchargers cause a drag(loss of crank power to run), but? doesn't an exhaust restriction also cause a loss of crankshaft power? Im not saying the same cam grind should work for both. Just that they both cause some kind of HP loss on an engine that were pushing-pulling them without the positive effects.
    Nov 2009
    Quote Originally Posted by sammyc57 View Post
    In the turbo world we call it LAG
    What are you saying. Having a cork jammed up the ass of an internal combustion engine might have some effect on the HP output
    LINK:GN-RACING.COM
    Abraham Lincoln
