SBC Cam ?
Page 1 of 3 123 LastLast
Results 1 to 14 of 29
SBC Cam ?
    Bullhead city AZ
    Default SBC Cam ?
    Working on building a SBC 383 stroker for my truck and im getting confused when it comes to picking the right cam. this will be my DD and im not to worried about gas mileage.
    So far i have the non roller shortblock and a new set of Vortec heads ready to bolt on. im going with a Edelbrock airgap intake, Holley 650cfm carb, HEI ignition.
    Now the truck is a 90 1/2 ton with stock TQ for now, i will change it out later when i beef up the trans and rear end.
    so ive been looking at these cams , but dont really know. Not sure need some input.
    http://www.summitracing.com/parts/CCA-CL12-242-2/
    I like the way these cams sound , really lopey but also heard they hurt perf?
    http://www.summitracing.com/parts/CCA-CL12-600-4/
    cfm
    cfm is offline
    Does it still have the tbi or is it carb'd ?
    Edit in: Okay, I think I can read...LOL....Carb it is.
    For a truck I'd go simple. If it's 4wd I'd stay with the good old standard Comp 268 High Energy. 218, 218 and 110 LSA. Should pull real well and give you good power to maybe 5000rpm or so. Peak HP should be close to 4500rpm. Shift low-mid 5k rpms.
    If your worried about more power past peak hp rpm and don't mind giving up some bottom end, then you can go with a split pattern on a 112 around the same intake duration at .050.
    Bullhead city AZ
    When its finished it will be carb'd
    cfm
    cfm is offline
    Your fast. You beat my editing above. LOL.
    cfm
    cfm is offline
    BTW, remember, if you have stock Vortec heads they are lift limited because of spring/retainer/to guide clearance. Some say less than .480" and some say less than .460" . Most are fine close to .480", but if you are going to use more than .460" you should have them quickly checked to make sure you are okay.
    I believe the 268H has .454" lift. Extra bonus.
    Bullhead city AZ
    Thanks , this is a 2wd street truck. been a project for the last 6 months and want to keep it very streetable
    not really looking for low end torque, more of a performance build.
    it wont be pulling anything and will most likely end up as a weekend toy when finished
    Bullhead city AZ
    My Vortecs have been machined for the bigger springs/lift, threaded studs and guide plates already
    There good to a 550 lift
    cfm
    cfm is offline
    Ahhh, okay.
    224,224 or 224,228/230 on a 108LSA and 2500 converter and 4:10 gears.
    Have fun ! For these specs I'd check ISKY. Tehy have a lot of cams on the shelf with 108LSA.
    Bullhead city AZ
    Ahhh, okay.
    Thanks i will do that.
    cfm
    cfm is offline
    I assume since you mentioned the Thumper Cams above that a 'semi-tough' idle is what your are looking for also ? If not, don't go by last suggestions.
    Bullhead city AZ
    Yeah , i do want it to sound tough. After all it does look good
    cfm
    cfm is offline
    201271 270-mega 2000-6200 ---270°/270° 221°/221° .465/.465 108°
    201274 274-mega 2200-6500 ---274°/274° 226°/226° .490/.490 108°
    Lake Havasu az.
    Quote Originally Posted by 2savage4you View Post
    I was trying to figure out what your avatar is....
    Some kind of Chinese air cooled piston? or maybe a rod journal cooler?
    Sheriff Joe Arpaio
    Bullhead city AZ
    Quote Originally Posted by Sold honda.bought hondo View Post
    Sorry i can only give you a small clue
