Header repair
Header repair
    BANDAID DUDE! HiMark Racing's Avatar
    Sep 2010
    Lincoln, California, United States
    Default Header repair
    Does anyone know someone in Northern California that does jacketed header repair?? I have a leak in one of my CMI Sport Tube headers, I would like to see if it's repairable.
    "When you see the tree you're about to hit, it's called under steer. When you can only feel and hear it, it's called over steer."
    Sep 2010
    Ended up sending to CMI. No one wanted to touch them. CMI told me $300 to pressure test, fix and clean up for the set. Fingers crossed!!
    I welded for Stellings in there header Dept. and they repaired outher Mfg. parts.
    Sep 2010
    Good to know. Thanks!!
