Dart 310 folow-up.
Results 1 to 14 of 58
Dart 310 folow-up.
    Default Dart 310 folow-up.
    Well the Dart heads are done and here are the results.
    Before:
    right/left ex
    .2 140 / 141 / 111
    .3 207 / 207 / 151
    .4 271 / 271 / 192
    .5 322 / 312 / 227
    .6 351 / 329 / 254
    .7 365 / 329 / 271
    .8 341 / 335 / 281
    Now:
    rh / lh / ex
    .2 166 / 165 / 117
    .3 216 / 214 / 165
    .4 281 / 279 / 193
    .5 328 / 312 / 235
    .6 356 / 336 / 258
    .7 365 / 353 / 278
    .8 365 / 360 / 288
    This was after quite a bit of work...far more work than I put into the AFR's and no where near the flow numbers. My goal was to balance the left/right imbalance, get the right port to not go backwards after .700, and pick up the low lift numbers...which I did, but interestingly enough, the .700 number on the right port didn't chcange one cfm. Given all the work I did, I would have expected to see some increase, but not this time. Still not bad numbers, but the AFR makes this dart head look silly with one tenth of the effort. Again, this was supposed to be a simple out-of-the-box, bolt-and-go set of heads that turned out needing a lot of work for mediocre results. I'm not bashing Dart, but AFR FTW on this one, big time.
    Derby, Kansas
    Thumbs up
    Thanks for the follow up Scott.
    Is there a reason why you and some manufacturers don't show flow at .100" lift? Do you have any pictures of them before and after?
    Arroyo Grande
    Before:
    Left/right/ex
    .2 140 / 141 / 111
    .3 207 / 207 / 151
    .4 271 / 271 / 192
    .5 322 / 312 / 227
    .6 351 / 329 / 254
    .7 365 / 329 / 271
    .8 341 / 335 / 281
    Now:
    rh / lh / ex
    .2 166 / 165 / 117
    .3 216 / 214 / 165
    .4 281 / 279 / 193
    .5 328 / 312 / 235
    .6 356 / 336 / 258
    .7 365 / 353 / 278
    .8 365 / 360 / 288
    good job on the heads......
    Southwest corner AR
    Looks like it's time for me to get busy! Good numbers Steel!
    Do you have the AFR numbers somewhere and I missed them?
    WT
    WFL Crew!!!
    Derby, Kansas
    Go to the dyno section and look for the AFR/Dart comparison it's on the first page post #14 had his final numbers.
    http://www.performanceboats.com/dyno...d-out-box.html
    Southwest corner AR
    Thanks!
    WT
    WFL Crew!!!
    another self promotional thread, part deux. The spam police will be here any minute to shut this thread down.
    Interesting info.Specially considering that Dart was suppose to have fixed much of the out of the box flow issues with the changes in the "Platinum" series
    LINK:GN-RACING.COM
    Abraham Lincoln
    another self promotional thread, part deux.........
    Damn GN, that's harsh. He's really here to "help" people, not simply just to promote his business. So Steel, someone told me that you did the flow measurments for Dart's ads when you worked there. Is that right, inquiring minds want to know? Regardless, good job on the flow numbers, they should make a very nice little street/lake motor... Ya'll take care now.
    Before:
    right/left ex
    .2 140 / 141 / 111
    .3 207 / 207 / 151
    .4 271 / 271 / 192
    .5 322 / 312 / 227
    .6 351 / 329 / 254
    .7 365 / 329 / 271
    .8 341 / 335 / 281
    Now:
    rh / lh / ex
    .2 166 / 165 / 117
    .3 216 / 214 / 165
    .4 281 / 279 / 193
    .5 328 / 312 / 235
    .6 356 / 336 / 258
    .7 365 / 353 / 278
    .8 365 / 360 / 288
    Interesting information Scott. just put a set of AFR 315 cnc combustion chamber heads on a customers 475. 13:1 with a decent looking bullet cam and a single dominator. looking forward to dynoing it as i had a similiar motor a few years ago with Brodix -2 cnc's to compare it too.
    Sep 2010
    What size motor are these heads going on? Are they for a boat or a car?
    Olympia, Washington
    The point was to try and even out the flow from right to left, what does it matter what size engine, or if auto or marine? Would you not want even flow between the heads, no matter what size engine or application it was going to be used in?eh
    Quote Originally Posted by tigertooth View Post
    The AFR 315 is an excellent head, much better choice than the Brodix-2 CNC IMO. Maybe a tad big for most 475's, but with 13:1 I'm guessing you're looking for some pretty big power and going to turn it up a bit. That 315 will serve you well.
    Green Bay Wi,USA
    Are the canfields going to resurface under a new name? I remember you seemed to like them.
    At one time I thought so, but at this point I'm not sure what the deal is.
