Magneto Question
Results 1 to 7 of 7
Magneto Question
    Coeur d'Alene, Idaho
    Default Magneto Question
    If your magneto is in perfect condition (Vertex) will it start the motor with a tap of the key like a distributor..or does the motor have to turn over a few times to generate the energy to fire...thanks
    Led
    Led is offline
    Senior Member Led's Avatar
    Jul 2010
    I have a blown alky with a mag, it takes mine a spin or two to fire, but could be due to alky. I dont think it should take long with carb gas deal. It doesnt take long for the mag rotor to make a rotation.
    Kingman/Golden Vly, Az
    Quote Originally Posted by Tittyman View Post
    If your magneto is in perfect condition will it start the motor with a tap of the key like a distributor..or does the motor have to turn over a few times to generate the energy to fire...thanks
    yes, it should start with a tap of the key...my set-up uses 2 buttons to start...one, which is a shut-off button that i push & hold to spin the motor to get oil pressure & the other to start the motor...works flawlessly...a Mag is self contained & mine will start on a flashlight battery
    Lake Havasu
    also depends on the mag... I put a MSD Pro Mag in my blown alcohol motor. Wouldn't start. Pulled a plug to check spark and it started. Put the plug back in, wouldn't start. Come to find out that MSD Pro Mag's require a minimum of 200rpm to start, pulling one plug made just enough difference in rpm's to make it work. Put a Mallory super mag in, no problem.
    okie, lake Texoma
    Mine starts so fast it'll make you jump, bet it doesnt make 1 rev. before it fires off.
    H8-2-W8
    5.89@139.4 first pass
    Senior Member HomeBlown57's Avatar
    Apr 2011
    Does anyone want a 5" autometer mag tach? Used waterproof.
    Senior Member jdekruyf's Avatar
    Jun 2011
    Artesia, CA
    I have a vertex as well (simple and reliable) and my set up is similar to fast rats except I have a toggle switch to control the ground. Get it turning over with a push button then flip the ground switch and pops off right away.
    Side note- you want to make sure the mag is always grounded when boat is stored or it will de-magnetize itself.
