not boat related but......
    Senior Member lilrick's Avatar
    Lakewood
    Default not boat related but......
    So I went to one my favorite ol stompin grounds last Sunday, AZUSA canyon. Saw some serious mud and alot of POS trucks with some horrible sounding motors. so, I was inspired to build a decent motor that will make some low end poop. I'm gonna turn some big tires and the truck will be a heavy ass chevy truck. What I'm not sure about is what cylinder head to use on a 488" motor. Id like to build a 488 That will run on pump gas. i'll be using a gm block, probably eagle crank and rods, solid flat tappet and a flat top piston. Looking for 9:1. My cylinder head choices are 990's , merlin oval ports, or a closed chamber oval (although i dont want the compression to be much higher). What say you?
    Quote Originally Posted by lilrick View Post
    Merlin ovals, but QJ will be here shortly to tell you ALL BBC need 990 heads and a tunnel ram. Period. Even motor homes and school buses.
    LINK:GN-RACING.COM
    Abraham Lincoln
    Lakewood
    The only reason I was leaning towards the 990's was the cubic inch. Tunnel ram is pure bling!!!
    So were the Boss 9 heads on that jet boat at the enduro! Kind of like Jerry's K boat. You can't polish a turd but you can roll one in glitter
    LINK:GN-RACING.COM
    Abraham Lincoln
