[Question] Cam swap
Cam swap
    Member bennyb's Avatar
    Mission viejo,ca
    Default Cam swap
    I'm getting a stock 454 out of a jet boat to drop into my daughters old LaveyCraft v-drive. I
    know the cam needs to be changed but don't know what I should change it to. Any help would
    be appreciated.
    Go on get your ass outa here
    Kingman/Golden Vly, Az
    Quote Originally Posted by bennyb View Post
    I'm getting a stock 454 out of a jet boat to drop into my daughters old LaveyCraft v-drive. I know the cam needs to be changed but don't know what I should change it to. Any help would be appreciated.
    my suggestion would be to get ahold of Chris (cstraub) here on the boards...he will steer you in the rite direction ...just sayin' my .02 cents
    Southwest corner AR
    More info on the motor would help for the best combo for a V-Drive!
    WT
    WFL Crew!!!
    be appreciated.
    If it's a "budget" deal, and you don't expect the engine to have to be a racer, there may be no reason to get into swapping the cam. Guess it kind of depends what's currently in it, if you even know that, and what your intended usage and RPM range will be in the V drive, including what type of exhaust you will be running.
