procomp heads question
Page 1 of 2 12 LastLast
Results 1 to 14 of 23
    Oct 2011
    Default procomp heads question
    Came across some procomp heads fully assembled today. Bbf, 2.19-1.88, look good. Anyone run these? They want 1000.00 for the pair. Junk or good for the money??
    Senior Member Futs's Avatar
    Orange CA, Big River
    junk...anything procomp is junk.
    well except the offroad suspension stuff thats been around for awhile.
    San Francisco Bay Area
    Quote Originally Posted by rpm0414 View Post
    Came across some procomp heads fully assembled today. Bbf, 2.19-1.88...
    That valve combination is physically impossible to run in that head
    A little bit of both, really: they are junk for the money.
    High Flow Dynamics
    This post © Copyright 2007-2016 Paul Kane. No copying, linking, printing or otherwise without express written permission.
    Isn't the offroad stuff a completely differenat company?
    To the OP, most around here feel as Futs does. Personally, I wouldn't run them because of what I consider unethical business practices, but that's just me. Based on what you read on bigger sites than PB, some have had OK luck with them and a BUNCH have had miserable luck. You'll probably be better off in the long run with a better know US brand like AFR, Brodix, Dart, etc... Good luck!!
    Jan 2010
    So Cal
    Your not supposed to mention P-- C--- in here.. No one told you?
    GN7 gonna shit
    Seriously, they're Junk. walk away.
    Southwest corner AR
    Save up your money and buy a good set of heads! You will be way better off! I do know that it's hard to come across good deals on FORD parts!
    WT
    WFL Crew!!!
    Find a good alum head pick the good one up in one hand and the pro comp one in the other and make the decision for yoursel! An assembled pc head weighs less than a bare brodix!
    If they were for a Chevy I would be all over them. There are a couple competitors I would like to buy a little some thing for Christmas. Those would be perfect.
    LINK:GN-RACING.COM
    Abraham Lincoln
    Probably thinks Delco makes the power that comes from his wall plugs,
    Yes. Pro Comp (suspension)is the name of a company. Pro Comp U.S.A. to be more precise.
    2 words Capitol P capitol C followed by 3 very distictive letters.
    Procomp Electronics, 1 word, small c followed by a word that tells you not to be buying heads and cranks from them. On top of the fact that the stuff is Chinese, which is getting harder to avoid, but Procomp Electronics is a Australian company. Does any of us need to be buying stuff made in China, and sold by a forgiegn company. The only "america" involved is the warehousing. Whoopee!
    On top of that fact, the stuff sucks as bad as the owner.
    LINK:GN-RACING.COM
    Abraham Lincoln
    Oct 2011
    Ya figured as much... Heads felt really light as in thin castings. LO , valves were close to that size. Not sure exact but somewhere near that. I'm a chevy guy so not familiar with ford., yet thanks guys for input.. I'll pass and keep looking
    yes it is, I was being sarcastic......
    Gone in a Flash! Speed of Heat's Avatar
    Lake Pend Oreille, Idaho
    The Bitter Taste of Poor Workmanship Lasts Long After The Sweet Smell of a Cheap Deal....JUST SAY NO!
    Remember that the Ark was built by amateurs and the Titanic was built by professionals.
    Members only MAXIMUS's Avatar
    Close by
    I am running a set on a 10-1 500 incher. Flat tappet hydrolic cam etc... I have been running it for over 5 seasons with no problems. However... if you look at the intake rocker stud boss on these heads they are about 4 threads thick. There is no hump in the port for extra support. The roof of the ports are really thin adding to lack of strength as well. I have heard through a friend of mine that they recently tore the roof off the port on the dyno just running the motor in. Flow numbers on them are pretty damn good however. Besides they are from Australia!
    okie, lake Texoma
    Your mistaken, the Procomps are from china and are pure junk. The ones from Australia are the Pro Top Lines and are a good head. I have a set that I ran for several yrs without any issues. They are pretty nice right out of the box. But I bought bare and put my own valves & hardware.
    H8-2-W8
    5.89@139.4 first pass
