spring help for new cam
Results 1 to 6 of 6
    Chandler, AZ
    Default spring help for new cam
    I am building my twin turbo motor up and am installing a new cam and need help with the lifters. Motor is a 454 with 8:5 compression with 990 heads and twin t6 turbos. Motor may see up to 20 lbs of boost. Cam is a .660 lift solid roller cam with 113 lobe separation and intake centerline. Heads are setup for dual springs. Max rpms 6800. Was running a flat tappet cam before. Let me know if you need any other info.
    Dan
    Surprise, AZ
    Are you saying .660 lift figuring in your rocker ratio?
    What motor is that cam from?
    Chandler, AZ
    Thats with 1.7 rockers. i also have 1.8 rockers so i guess need springs good to just over 700 lift if needed. Yea decided to go with a solid roller cam and go bigger. The cam in it was a flat tappet cam with 540 lift.
    Dan
    Chandler, AZ
    Cam is a new cam custom ground. Just got it today from comp
    Surprise, AZ
    I would assume comp would give you a recommended spring for that cam?
    Chandler, AZ
    Yea they left the cam card blank in the spring recs.
