Amatuer needs help
Results 1 to 8 of 8
Amatuer needs help
    Amm
    Amm is offline
    Amatuer
    Utah
    Default Amatuer needs help
    So I finally got my 350 put together and ready to start. Of which I thought was a hydraulic roller vortec engine.
    I go to start it and I already know something is wrong. Sounds like no compression. Sure enough, none of the cylinders have compression.
    I back off on the valve adjustment and I get compression on that cylinder. I do the the following adjustment again:
    1) make sure top dead center for that cylinder
    2) while rotating pushrod, tighten the nut such I feel when the rocker engages.
    3) tighten another 1/2 turn.
    Result: still no compression
    Well I did the same thing, but this time 1/4 turn
    Well I did the same thing, but this time no extra tightening
    Result: compression.
    I know they are roller lifters, what are the odds that I have solid lifters or am I just doing the #2 step wrong or is something else very wrong?
    Any help would be appreciated.
    Aug 2010
    Chino Hills, southern California
    Default Lifters, pump em up?
    Just curious, I remember having to "Pump up" the lifters. What I did was fill a small tin can with oil then repededly pump the top of the lifter with a pushrod, untill it was full. Full meaning it did not compress. After doing this assemble the rest of the engine then prime it using a dummy distributor with the gear teeth machined off. If not the lifters must rely on engine oil pressure to pump them up.
    Senior Member Mash on It's Avatar
    Willow Beach & BHC
    On a properly adjusted sbc valve, the pushrod will turn pretty easy, and using the "spin the pushrod" method maybe too tight. I feel for zero lash by "jiggling" the pushrod up and down, then 1/8 to 1/4 turn, or .060" preload
    Here is a way to adjust the valves by turning the crank once
    #1 TDC
    EX 1 3 4 8
    IN 1 2 5 7
    #1, 180* out or #6 TDC
    EX 2 5 6 8
    IN 3 4 6 8
    Hope this helps
    Daniel
    Mash on it
    "Never mind the mule, Just load the wagon"
    '76 Eliminator 21'
    Senior Member steele211's Avatar
    Nov 2008
    Kingsburg,CA
    I went through this same exact thing on a mark IV bbc. I found after some research that it was a solid lifter cam. Lashed the valves as such and fired and ran beautiful. It sounds to me that this might be the case for you as well
    Quote Originally Posted by Mash on It View Post
    #1 TDC
    EX 1 3 4 8
    IN 1 2 5 7
    EX 2 5 6 8
    IN 3 4 6 8
    Hope this helps
    Daniel
    Mash on it
    wuz gna say you're right about how to adjust the vortec 305 and 350's right up until i noticed you forgot to adjust ex 7 and adjusted 8 twice
    but yeah by the gm book you do the 2 step method on all v8 vortec sbc's
    Amm
    Amm is offline
    Amatuer
    Utah
    Well, I tore it back down to long block stage so that I could inspect the lifters.
    I put a lifter in a vise between a large socket to hold it and a small socket to apply pressure like the pushrod. Oil started to bleed from the side of the lifter. So it has to be hydraulic lifters.
    In researching this, I noticed my rocker arms did not look quite right. Well, I need 7.122" as opposed 7.724" pushrods. I got those ordered, but then I started to double check other things. My roller cam does not have a mechanical fuel pump provision. Oops.
    Well, anyone want to recommend a camshaft? 350, vortec heads, edlebrock performer dual plane intake. This is going in a twin engine 26' deep vee. It says Scarab on the side of the boat, but I am pretty sure its a Nova. Probably a camshaft similiar to mercruiser's 5.7 HO.
    Willow Beach & BHC
    oops.......fat fingers
    #1 TDC
    EX 1 3 4 8
    IN 1 2 5 7
    180* out or #6 TDC
    EX 2 5 6 7
    IN 3 4 6 8
    Hope that helps
    Mine has two #8 exhaust valves (better than NO2)
    Mash on it
    Daniel
    '76 Eliminator 21'
    Willow Beach & BHC
    Quote Originally Posted by Amm View Post
    Do you need a mech fuel pump?
    Try a ZZ4 cam
    Camshaft lift (in): .474 intake / .510 exhaust
    Camshaft duration (@.050 in): 208* intake / 221* exhaust
    OR a LT4 hot cam
    Hot Camshaft (P/N 24502586 Specifications
    Intake Exhaust
    Lobe Lift 0.328” 0.328”
    Valve Lift
    @ 1.5 ratio
    @ 1.6 ratio
    0.492”
    0.525”
    0.492”
    0.525”
    Duration
    @0.050 cam lift 210° 228°
    Thats all I got
    Daniel
    Mash on it
    '76 Eliminator 21'
