wanted, pyro sys
Results 1 to 2 of 2
wanted, pyro sys
    Senior Member culprit294's Avatar
    sydney
    Default wanted, pyro sys
    has anyone got a pyro sys x 8 with read out, or where can i bye one. dean
    Quote Originally Posted by culprit294 View Post
    Dean, the first is a data logger that they might be able to set you up with a display.
    LINK: 8 ch egt data logger
    The second is a scanning aircraft EGT guage. I would think you find something like this over there if this works for you. If you have time to look at the display of 8 cylinders you not busy enough
    LINK: Digital 8 ch aircraft EGT
    This one you can see all 8 cyl on a bar graph
    LINK 8 cyl bar graph
    LINK:GN-RACING.COM
    Abraham Lincoln
