carb info
Results 1 to 7 of 7
carb info
    Oct 2011
    Default carb info
    Pulled motor for winter rebuild project and trying to do some research on the stock carb that was on the 460 bbf. List is 6361. One site says 780 cfm, some say 650 cfm. Anyone familiar with this carb? It's vac secondary.
    It is a 780 cfm made for Ford Marine motors.
    Look like this? If so it is the 780.
    Oct 2011
    Yes exactly like that.. Why Holley site say it's 650??
    Quote Originally Posted by rpm0414 View Post
    There are two with that number. You need to check the Ford part number.
    Oct 2011
    Mine is exactly as your pic. Well that's better. Was thinking 650 little small. You think that carb ok for 425-450 hp 460??
    Senior Member jyeager's Avatar
    Sep 2010
    West Covina, California, United States
    I would Swap that 780 for a 850. Those 460 fords love there gas. Did it on mine made a world of difference.
    Check out my work here --------> http://www.fairplex.com/fp/ctec/index.asp
    Decals? go here------------------> https://www.facebook.com/StickersByJosh
    Like McIntyre Snob here -------->https://www.facebook.com/McIntyreSnob
    Southwind 18 460 ford
    Southwind tunnel dragster 468 Chevy
