fuel bypass help
Results 1 to 13 of 13
fuel bypass help
    MD
    Default fuel bypass help
    Im revamping my fuel sys. this winter
    what im looking for is an inline fuel pressure reg. 7/8psi that i have seen on some blower motor gas and alke
    it looks like a brass inline fitting non adj.
    from what i have seen it's eather a idle or hi speed bypass
    what im trying to do is from fuel pump Mallory 140 marine to a tee from tee to carb and to the bypass from bypass back to tank
    hope this makes sents
    Do you guys think this will work?????
    Administrator Infomaniac's Avatar
    Locust Grove, OK
    If it's plumbed into a return line it is an Enderle valve. Same as all of the enderle valves you see on injector hats but setup for 7 PSI or whatever you request and shims to adjust it. . Call them they will fix you up. I use them quite a lot. Works perfect. Or I will fix you up with one if you don't buy direct from them.
    QE 439 Twin Turbo
    If it's plumbed into a return line it is an Enderle valve. Same as all of the enderle valves you see on injector hats but setup for 7 PSI or whatever you request and shims to adjust it. . Call them they will fix you up. I use them quite a lot. Works perfect. Or I will fix you up with one if you don't buy direst from them.
    Ron, what's the advantage of a bypass over a deadhead style regulator?
    MD
    Thanks Info
    Thats it
    Default Heat
    Deadheaded fuel will get hot in the pump when it can't move... Not only heating the pump vanes, but the gas!!! AND, you can adjust the pressure very closely by adding, removing shims behind the poppet spring...Very precision...
    Ray
    LOUD BOATS SAVE LIVES
    Locust Grove, OK
    What Moneypit said plus there is absolutely no device in the path of the fuel between the pump and carbs or whatever. It's much better to feed them more fuel than they need and bypass in parallel whatever is not needed. A lot easier on the pump.
    Been doing this for years and recommend it to everyone. I believe anymore there are some deadhead regulators that flow a lot but why use one? They are much more expensive than a smple bypass valve. Turbine engines use bypass systems. All EFI systems are bypass. I have a bypass valve from hell on the twin turbo.
    QE 439 Twin Turbo
    MD
    You have been good to deal with in the past
    Im with ya on the best way to go... price, simple, clean, less heat and functional
    So You got a PM
    Dave Koehler has them for $49 or set to your psi for $60 thats cheaper then a good bypass reg.
    Default Set it yourself...
    So You got a PM
    Very simple to make a "bypass pressure" checking system... A good low scale pressure gauge, (for carbs, mech injection is much higher), a "T" with a dump, (radiator petcock will work), and an air source with a regulator.... Bring pressure up with the petcock open slightly until the poppet pops, note the gauge... Make necessary changes, re test.... AND, you'll be working with a new valve that seals very well below desired dump pressure..... Have fun.... Get use to it, and step right on up to mechanical injection!!! Just add 1 or 2 more by passes!! And a cam driven pump...
    Ray
    Locust Grove, OK
    When we built the Dragstar and used 2 alcohol carbs. I took an enderle valve and removed the check valve and put a pill in it. It had a Ron's gold belt driven pump. I jetted the bypass so it had 7 lbs or so at idle and after a couple thousand RPM had about 15. After the needle seats are open it doesnt matter.
    I don't reccomend you do this but it's how versatile those Enderle valves are. You won't be using a pill but the valve will be threaded for one.
    I'm using one right now as a bypass on the Daytona to regulate the water pressure to the engine.
    QE 439 Twin Turbo
    MD
    I didn't think about that :<)
    is it all brass and S.S???
    Locust Grove, OK
    Just the brass valve body and a brass pill. No check valve.
    QE 439 Twin Turbo
    MD
    Ray
    Thanks money that is a good way, but i already have a tester to set it with. I was just putting that info out there for others.
    I will be getting the $49 one and at that price i may get 1 for the water aswell :<)
    MD
    Im talking about the spring and shims w check valve set up
    or is the one your talking about different than the one Dave is selling ???
    Koehler-Enderle idle secondary hi speed Bypass Check Valves fittings
