Intake manifold porting
Results 1 to 11 of 11
    PRB
    PRB is offline
    Discovery Bay
    Default Intake manifold porting
    Hi guys, i have an Edelbrock Victor Ram that i would like to get ported for my 555 BBC. I bought the manifold some years back and it was more of just a lake motor, now it is pretty much a full tilt race deal so i would like to squeeze everything i can out of it. Just curious who some of you have used in the past and recommend, thanks in advance!
    Diamond Bar, Big River
    pm Steelcomp here on the boards. He'll prolly have a good recommendation for ya.
    Senior Member badnews's Avatar
    Send it to Michigan to Lapouttre racing heads and engines. Rick is by far the best there is he worked/works for dart heads prototyping and does amazing work with big hp numbers !!!
    989-893-5028 call him and talk to him
    "BadNews always travels fast"
    Senior Member hotbo's Avatar
    lake Ouachita AR
    Quote Originally Posted by jetjunky View Post
    X100
    WFLC
    2011 Performer SS
    built by Scott Seastrom.
    Senior Member tt005's Avatar
    What kind of hp gain could you achieve with a good port job?
    Quote Originally Posted by PRB View Post
    What's the application on the 555? The Vic Ram is pretty good out of the box as far as runner size, but it might need a little work for a 555 turning some rpm. Mostly, they need a LOT of cleaning up in the plenum area around the runner entries. That, and some plenum volume.
    Stiegmeier porting service in st charles mo is good and do great work
    PRB
    PRB is offline
    Discovery Bay
    The engine is in a 500lb runnerbottom that i plan on running in the njba next season. Im gonna keep the max rpm at 7500, i have seen a few of these manifolds with a plastic spacer between the manifold and top plate. Im guessing that aids in the plenum volume and im also guessing they are custom made and not something you can just buy from summit or your local speed shop. Thanks for the responses.
    waterloo
    Hijack again...
    OK, Steigemeyer does do good work. He is a character. LOL But, beautiful work. Have dealt with him a bunch years ago.
    Hey, porters... I see the 3m 747d abrasive in 60g seems to be the fav. I have blown up my last damn cheap roll and threw them all in the trash. (hot head). So, where can I buy them without the raping? And whos mandrels are you using with them? A good piece.
    AND does the dimmer switch thing work without killing electric grinders... or should i just buy the router control, or a variable frequency drive?
    I have an old ???? Corporation from Racing WI grinder. Model 8524-210 I can't even read the name on it anymore. It is probably 20+ years old. Light. 15000 rpm max. It is black... I sure wish I could read the tag. I have replaced brushes and bearings over the years a few times. It is a workhorse, though. Dumore maybe??
    Wags
    I'm No Expert Shaun's Avatar
    San Clemente, Ca
    DNE used to carry these but last i checked with Dave he didn't have the program for them anymore because of a hard drive crash his supplier had. Not sure if that's still true because it's been at least a year since I've checked back in with him. If you find these let me know because i'm looking for one too!
    Hijack again...
    Wags
    Dumore is a nice piece, the Foredom flex shaft is a nice pice too.
    Foredom ktxh440 flexshaft with 1/8" & 1/4" collets. As for the wheels Roloc 2" Bit's coarse 1/2" carbide, 1/4" oval Sanding rolls, 36 & 50 grit straight and taper for 1/8" shank.
