School me on BBC
Results 1 to 8 of 8
School me on BBC
    Stole it! BlubyU's Avatar
    Nov 2009
    Tucson,Az
    Default School me on BBC
    So.. here's the deal have a 454 in my boat now, thing has close to 500hours on it. Probably time to do something with it, it's tired. I ran across a deal on a rotating assembly for a 502 all Merc racing parts (Crank, Rods, Pistons)
    I am no expert when it comes to BBC bore size, crank and all... I don't think you can take a 454 to 502 cubic inch with a 4" stroke correct?
    2011 BOSS302R
    Nov 2009
    Tucson,Az
    Fasglas...
    Thanks that's the answer I was looking for. Search is on...
    2011 BOSS302R
    Dec 2011
    I haven't kept up with the latest offerings from GM, but in the past the 454 block was a different block and would not bore big enough.
    Quote Originally Posted by BlubyU View Post
    Fasglas...
    It's not possible to bore a regular GM 454 block to accept a 502 (4.470") piston into it. On top of that, the 502 assembly is probably for a late model block, which has a 1 piece rear main seal, so unless you had a late model 454 block, it's also not directly compatible. Both the 454 and 502 have 4" stroke cranks.
    waterloo
    All you need to know is a big block is so yesterday. A LSX with efi is where its at. Especially if you want to spend a bunch of money and get less.
    HAHAHA
    Wags
    Nov 2009
    Tucson,Az
    HAHAHA
    Wags
    Wagspe208... I hear ya on the LSX with EFI. At this time it doesn't permit though. Thanks for the help.
    Ordered a brand new bare block.
    2011 BOSS302R
    Did you order one of those Pro Comp 502 blocks? If so, I will be curious to know how that works out.
    Nov 2009
    Tucson,Az
    Negative... A brand new one from GM 1763$
    I am here: http://maps.google.com/maps?ll=32.312222,-110.847019
    2011 BOSS302R
