514 BBF Dyno Issue
Page 1 of 11 1234 ... LastLast
Results 1 to 14 of 144
514 BBF Dyno Issue
    Member 1980condor460's Avatar
    Newcastle
    Default 514 BBF Dyno Issue
    My Freshly built 514 went to the dyno today to some very dissapointing numbers. With that said I need some help - I didn't expect my engine's first pass to end up with 422hp. Don't remember the tq off the top of my head, it was less than the hp. I haven't seen the printout so I don't even know how many rpms it pulled.
    Here are some specs -
    514 rotating assembly bored .80 over with Flat top forged pistons. Dove C heads. Tunnel Ram with dual 650 carbs. Cam is a Comp 34-343-4. Gross Valve lift - .640 intake and .640 exhaust. Duration @ .050 is .262 intake and exhaust. 3 angle valve job has been completed on the heads but I do not have flow numbers.
    Any ideas on what can be holding me back? To much Cam, not enough flow? My mechanic said there is some corrosion on the carbs but the engine was not running lean during the initial pull. He is going to rebuild the carbs and go again.
    Led
    Led is offline
    Senior Member Led's Avatar
    Jul 2010
    what size valves in the heads? It should have made more than that, whats the timing set at? what fuel you running?
    Newcastle
    Dont remember the valve sizes. I will have to call tomorrow and check.
    Last test today was 470hp and 523tq. Stopped making power at 5100 rpm. Dyno guy says that it is probably the heads.
    I also remembered that it has D3 heads NOT D0VE heads on it because I wanted to keep the compression down with the flat top pistons.
    I have a set of edelbrock aluminum heads I am going to take to him next week. What size valves SHOULD I be running with the set up. It sounds to me like I am running out of air.
    Close to the water...
    Pop off a valve cover and recheck the cam card specs!!!
    Apr 2010
    Rocklin, Calif.
    Who's doing the dyno..I had the same problem with not enough air
    Quote Originally Posted by 1980condor460 View Post
    Air and feul. Sounds like the motor is laying down big time. Did you bother to check the plugs for color??? I would bet that the plugs are snow white. Without A/F readings it would be precision guess work. M
    Dont remember the valve sizes. I will have to call tomorrow and check.<br>
    <br>
    Last test today was 470hp and 523tq. Stopped making power at 5100 rpm. Dyno guy says that it is probably the heads. <br>
    <br>
    I also remembered that it has D3 heads NOT D0VE heads on it because I wanted to keep the compression down with the flat top pistons. <br>
    <br>
    I have a set of edelbrock aluminum heads I am going to take to him next week. What size valves SHOULD I be running with the set up. It sounds to me like I am running out of air. <br>
    <br>
    Newcastle
    Brad Smith (Smith Power) up in Joplin, MO. He admitted that he usually deals with Chevy's. I didn't get the air fuel ratio from him. Last time I spoke with him - he suggested that we take a hard look at the heads. So - what size valves should I be running? Will the D3 heads work with this application or am I pissing in the wind? Who does good head work on Ford stuff? Brad said that he has a "guy" but I wouldn't mind hearing who folks from this forum recommend.
    Oct 2011
    Call high flow dynamics. Ask for Paul. He is pretty savvy on ford heads. Google their website.
    If the engine is running lean, fire the dyno guy. If the engine is running out air because the room isn't ventilated correctly, take it some where else. If the cam was installed with a common T gear, and wasn't CORRECTLY timed in, fire the builder. If it was you, and you didn't time it in, shame on you. If the cam is timed in straight up using a standard off the shelf T gear, it could easily be 4+* retarded. With that long ass cam with that compression and 4+* retarded, it could very possibly be a pig.
    The Ford head is capable of making more power than that.
    LINK:GN-RACING.COM
    Abraham Lincoln
    Salem,Or
    Ya what he said, I think its about 8 degrees retarded if you do it that way??
    If I remember right those heads should handle up to 700 hp???
    But ya talk with Paul highflowdynamics@earthlink.net
    www.highflowdynamics.com
    check out the 460ford.com site
    With Spray there is a way!!!
    Newcastle
    I did not build it. Dyno guy didn't run it lean and I doubt air in the dyno room is an issue either. This engine is tiny compared to some of the blower motors comin out of his shop. My first call tomorrow will be to the engine guy to get the cam timing and valve specs, second call will be to Paul. Will keep you guys posted. Sounds like I may have made a poor cam choice for my combination.
    Okay lets just put it straight out WHAT DO THE PLUGS LOOK LIKE??????
    Okay lets out it straight out: What were the A/F readings?
    And what is your calculated compression?
    Carbs are messed up, timing is off, cam installed retarded start there.
    S CP
