[Question] Which Head Gasket??
Results 1 to 8 of 8
Which Head Gasket??
    BANDAID DUDE! HiMark Racing's Avatar
    Sep 2010
    Lincoln, California, United States
    Default Which Head Gasket??
    Need some quick info..
    Which Head/Intake gaskets would work best on a BBC 540 Tall Block with a 14-71 Blower (8 lb boost) ???
    Thanks in advance!!
    "When you see the tree you're about to hit, it's called under steer. When you can only feel and hear it, it's called over steer."
    I have a 540 BBC tall deck with a 14-71 also and I have had very good luck with the Fel-Pro blue gasket.
    Sep 2010
    Are those the MLS gaskets??
    Quote Originally Posted by HiMark Racing View Post
    NO. The MLS are black and rougly twice the money. You don't need anymore than this unless you running a compression above 9 to 1 and race gas.
    This gasket can hold anything running on pump gas so long as you don't throw it into detonation.
    LINK Felpro 1047 head gasket
    LINK:GN-RACING.COM
    Abraham Lincoln
    Sep 2010
    Static compression is @ to 13 to 1.. 1075-1 just ordered.. And you ain't kidding on the price!!
    Senior Member racinjason65's Avatar
    May 2011
    Huntington Beach
    I have had nothing but good luck with Cometic! That's what I'm currently running on my 565 with a 1471....6lbs on pump and 11 lbs on good fuel. I think that head studs and proper torque (after heat cycling) is more important than the brand of head gasket.
    Member Cole555's Avatar
    Sandy OR
    Default Head Gasket
    I use the SCE Copper Head gasket TITAN self sealing , not cheap but a very good gasket .
    get mine from good vibrations
    Tri-Cities, TN
    Quote Originally Posted by racinjason65 View Post
    Cometic and don't look back.
    Chris Straub
    Straub Technologies
    3HP is an A$$ Whooping!!! JW
