My Spark Died
Results 1 to 6 of 6
My Spark Died
    21' Liberator Jet NORDIC454's Avatar
    BIG D
    Default My Spark Died
    I have been reading horrible reviews on MSD quality lately. I was planning on running Digital 6 on my 13.5:1 496 w a single stage plate. What alternatives are out there that work? I have only run HEIs in the past so I don't have any experience with boxes. I really like the features of the digital 6, start retard, single stage retard, and built in rev limiter. I have an MSD billet dist if that matters.
    TIA
    Southwest corner AR
    That is what I have on my 496 and 555 and it works great! I do wish that the dig 6 box would go a little bit more on the retard for the NOS! 9* is all you can pull out! And if you load 300+ shot you have to pull the dizzy back! Quality has slipped a bit but they do have a good service department!
    WT
    WFL Crew!!!
    BIG D
    I thought about just rolling the dice on one. No other box has the same features with out doubling the price. A 7 box seems way too complicated for what I'm trying to do anyways. I don't know anyone that runs something other than MSD or HEI.
    Southwest corner AR
    You will like it for simple operation! And MSD is better than some options out there! Good luck!
    WT
    WFL Crew!!!
    Not sure which box you have but the MSD 6530 allows for up to 30* retard from a trigger wire.
    MSD 6530 Programmable 6AL-2There is a single step retard that is controlled through the Pink activation wire or through rpm. It can also have an rpm point that the engine must reach before the retard becomes active (a minimum rpm can also be programmed that must be reached before a step becomes active). A time based ramp can be programmed to gradually bring the retard to its full On amount, or to ramp the retard amount out (back to no retard) from its setting.
    Activation through Wiring: The retard is activated when 12 volts are applied to the Pink wire. The maximum retard allowed by the ignition is a total of 30° (including other retard amounts or a boost map).
    LINK:GN-RACING.COM
    Abraham Lincoln
    Tri-Cities, TN
    Quote Originally Posted by NORDIC454 View Post
    TIA
    We have tested the Daytona-Sensors stuff and are now stocking it. It is tough stuff and they have a marine USCG approved box. Digital and will wire into any type of "dumb" distributor.
    Chris Straub
    Straub Technologies
    3HP is an A$$ Whooping!!! JW
