head gasket reommends
Results 1 to 11 of 11
    Default head gasket reommends
    have a 572 cu in merlin block/rhs heads,copper head gaskets o ring block. can see stains were water is sneeking into valley (thats the prob water in oil) everything else looks good. which head gaskets would be good to use and would they use take the deck ring? steel/obnoxis anybody? thanks
    BANDAID DUDE! HiMark Racing's Avatar
    Sep 2010
    Lincoln, California, United States
    I had the same issue..turned out to be intake leaking.
    "When you see the tree you're about to hit, it's called under steer. When you can only feel and hear it, it's called over steer."
    Quote Originally Posted by ibelio View Post
    What are you using around the water jackets with the copper head gaskets?
    I learned to use a thin coat of the hi temp silicone over 30 years ago when I worked for Gale Banks.
    waterloo
    Receiver grooves? Of course not.
    Silicone is recommmended for sealing around water ports. High temp. Ultra black is my fav.
    Receiver grooves SHOULD be there.
    Let the arguing begin.
    Now, everyone will add the "I have not run receiver grooves and never had a problem".
    To that I will say "I have nailed more than 1 bar tramp without a rubber and never had a problem." That don't make it right.
    Wags
    Nov 2008
    Orangevale CA
    Wags
    You Know Wags , I have heard you say this about the bar tramps before ,, so maybe you could take obnoxious 001s advice , He learned to use a thin coat of the hi temp silicone over 30 years ago !!!!!!! ...... E
    [QUOTE=J Shelfo; My all time favorite quote; Flatbottoms are like shopping carts, every once in a while, you get a good one.....
    Wags
    Quote Originally Posted by alkyexpress View Post
    I want to know if the bar tramp could make the same statement after nailing Wags You know what they say about pendulums
    LINK:GN-RACING.COM
    Abraham Lincoln
    Nov 2008
    Orangevale CA
    He does make the statement " Receiver grooves SHOULD be there. " , .....
    Dec 2011
    South Carolina
    I always liked using loctite 518 for copper gaskets. Never had a water leaking problem and it's alot easier to get the head back off than when i used silicone. Now about these bar tramps, we need pictures. lol
    Arroyo Grande
    [To that I will say "I have nailed more than 1 bar tramp without a rubber and never had a problem." That don't make it right.
    Wags[/QUOTE]
    to the Bar tramp I call Bullshit...pictures...we need proof...that tramp you speak of could have been the neighbors sheep
    sorry, the rings are only around the top of the cyl bore
    waterloo
    ROFL. You guys make me laugh. That was when I was younger and wilder....er.... not in a relationship. You know the gig.
    Maybe the bar tramps did say the same thing. HAHAHA
    Wags
    Oh, and the neighbor only has cows. I'm not that tall. And they aren't stump broke!!
    I make me laugh too.
