jetting on Holley?
jetting on Holley?
    Oct 2011
    Default jetting on Holley?
    Another motor question guys-- when I rebuilt my carb I noticed front jets were 72's and rear were 84's. Holley lists this as stock. Wow that's quite a rich secondary? Is this normal for jet boat? Once again the boat thing is new to me so just asking.
    S&S
    S&S is offline
    Steve S&S's Avatar
    May 2011
    Granite Bay, Ca
    Probably no power valve provision in the secondary side metering block. Power valve ads something like 8-10 jet sizes.
    Quote Originally Posted by rpm0414 View Post
    S&S is right. You looking at this from the wrong end. Its not that the secondary is rich, its that the primaries are jetted for lean cruize. When the carb is open enough to bring in the secondaries, the PV on the primary side will be open and the jetting will be much more equal.
    I would GUESS that this is a vacuum secondary carb, or an possibly an early double pumper. Most hi perf carbs have a closer pri/sec jetting because the power valve restrictor jet tends to be smaller than street carbs. Realistically, most newer double pumpers and hi po carb PVs add closer to 4-6 jet sizes, were as street carbs can add up to 8 or 10 as S&S posted.
    LINK:GN-RACING.COM
    Abraham Lincoln
    Oct 2011
    Got it. Yes vac secondary. Makes sense, I'll keep it like that then. Ran good before new motor build. Rebuilt it and noticed difference. Thanks guys
