Aeromotive or magnafuel hex drive pump?
Results 1 to 6 of 6
    Chandler, AZ
    Default Aeromotive or magnafuel hex drive pump?
    I am still trying to decide on a pump (1200 hp tt BBC in a jet boat). My engine has a timing cover setup to run a mechanical pump. What would you reccomend? Also what else is needed to connect it to the cam besides the hex drive adapter? Does it clear the balancer, or do I need a spacer?
    Thanks Dan
    Default racepump
    I'd use a piston type mech pump if I were you. racepumps.
    Chico, Ca
    Aeromotive
    You need the same pump Mark (unchained) has on his TT engine.
    Chandler, AZ
    I ended up ordering a belt drive since I wasnt sure the cam one would clear the balancer I had. I got the aeromotive one(same as mark is using). Okiedave, I really wanted to use the race pump, but never heard anything good about it with efi. Dont have to have to buy 2 pumps.
    Dan
    Green Bay Wi,USA
    The Bracket to support the pump off the timing cover bolt holes in the block, can be seen on the rbs superchargers website. I purchased one for my enderle from them.
    Senior Member slow67's Avatar
    DFW
    I've read that the aeromotive pumps suck better than the enderle pumps (if your feed line goes uphill).
