BBC Timing Pointer
Results 1 to 14 of 15
BBC Timing Pointer
    Kent, WA
    Default BBC Timing Pointer
    Made a couple more of these. These are Right hand side BBC pointers
Name:	BBC Timing Pointer.jpg
ID:	144876   Click image for larger version.
Name:	BBC Timing Pointer 2nd.jpg
    Jun 2011
    spokane, wa
    Another Top Notch part Brian!!!!
    Default Very nice, but....
    Very nice parts, but why on the right side? Is there something in the way on the left side where #1 is?
    OR, is it something to do with gen V or VI?
    Ray
    LOUD BOATS SAVE LIVES
    ptc
    ptc is offline
    Senior Member ptc's Avatar
    Oct 2010
    Sacramento Area
    Will this work with a 6.75" balancer???? I'd like a billet style but cant find anything for the smaller balancer
    Kent, WA
    The right side is much easier to get at.
    The guy driving this boat seems to have some long legs and the seat is back up against the left cylinder head ?
    Then all the plumbing is crammed in there too ?
    The right side is open to eye sight.
    We positioned it so you can see the timing above the crank support and below the blower belt guard.
    I'm not sure this one would be really good for your 6.75 dia with this pointer, I am sure St John could make the same bracket and just make the pointer itself offset to the smaller diameter ? If you'd like, I can ask him.
    ptc
    ptc is offline
    Oct 2010
    Sacramento Area
    That would be greatly appreciated, I need to get my timing set and this is just another one of those little PIA things to get finished.... and done right! Thanks
    Quote Originally Posted by ptc View Post
    Not to talk you out of his trick part, but there are many available for 7" damper, so the pointer would be 1/8" from the damper. I just found one for a 6.25" damper on an engine I am working on, have not specifically looked for 6.75"
    Kent, WA
    I totally agree, if you can use one on the left side ?
    Did you need a left or right side application ?
    ptc
    ptc is offline
    Oct 2010
    Sacramento Area
    Yea now that I looked there are many avail out there. I measured my balancer and it measures about 6.5" dia. does that sound right? Dont really see any pointers for a 6.5" so do I use a 7"?
    Left or right - are you talking about facing the motor? I assume all the avail ones are made for the right side? a left side type would work nice for mine cause the right side is pretty full:
    Castro Valley, Ca.
    Paul
    Moroso makes one for a 7" balancer on a BBC, don't think an 1/8th of an inch difference would cause a great problem. The Moroso mounts on the right side, looking at the engine from the front.
    Larry
    62 Bel-Air 409
    260 Eagle XP HP500EFI
    2016 Corvette Z51
    Remember in November
    Well done USN Seal Team 6
    cfm
    cfm is offline
    I prefer the pointer to be as close to the balancer as humany possibly. That way you'll know exactly what the timing is even if your looking from a slightly different angle.
    Get an adjustable (in degrees) pointer for your exact diameter damper. Obviously, find #1 exact TDC when putting pointer on and adjust so it points at exact #1 TDC.
    You sure your balancer is 6.5" ? Not a very common BBC size. I'd measure exactly and/or contact manufacturer.
    Kent, WA
    When I was talking about right vs left, I'm talking about how the engine is in a car. Sorry.
    For me , left is the original side ( 1,3,5,7 )
    Right is in front of the fuel pump mount ( 2,4,6,8 )
    I know there are all kinds of them for the original mounted side , Cyl 1 side.
    Like stated , better measure your balancer od.
    ptc
    ptc is offline
    Oct 2010
    Sacramento Area
    I'll have to get out my dial calipers and put a measure on it. With a tapemeasure it looked about 6.5, but could have been 6.375. It is definately not 6.75 as originally told. I saw the Moroso P/N 60130 - they show it as a 6.250"
    Moroso : Category Display
    Right hand YES - on the fuel pump side, see my pic thats the empty area. Yours are probably for 8" balancer?
    9.00@125MPH
    Ohio
    Putting the pointer on the other side of the engine going to mess up the timing marks?
    Tim
