holly carbs
Results 1 to 14 of 20
holly carbs
    Senior Member ohflat's Avatar
    Nov 2008
    Default holly carbs
    who is the carb guru i have 2 850s i would like reworked and set up with my build sheet they stutter on hard accl and wont idle 7300rpm is alli get builder says i have 5or600rpm to find motor is good for 8000
    Senior Member progas's Avatar
    Feb 2010
    San Diego/Walters Camp
    Joey Gross
    Where are you located.
    don't be so fast to blame the carbs for your RPM. Idle and stumble is one thing. But if you think that 2 850 carbs are holding you back 500+ rpm, I doubt it. RPM is a HP deal. If you don't have the power to haul the gearing and prop, along with the weight and wetted area of your boat, all the carb work in the world won't help.
    There is a limit to the gear and prop in a given boat that the engine can handle.
    LINK:GN-RACING.COM
    Abraham Lincoln
    Jan 2011
    Mickleton, New Jersey
    Quote Originally Posted by ohflat View Post
    you should have set it up on a Dyno, Good luck
    Nov 2008
    Default carbs
    ohio
    Nov 2008
    Default carbs
    i be happy getting rid of the stutter and poor idle condition
    LINK:GN-RACING.COM
    Abraham Lincoln
    Kent, WA
    Sv-1
    Sv-1
    They are bad ass, but like he said, he would be happy to get rid of the stumble and have it idle. I don't think he is trying for Space Shuttle throttle response.
    LINK:GN-RACING.COM
    Abraham Lincoln
    waterloo
    Well, the one guy will tell you EFI is the only way to have something run right.
    Wags
    Nov 2008
    Default carbs
    iam sure some of my issues are lack of tunning skills as i read into the threads
    I use a holley catlog and a Quick fuel catolog and from that compare stock settings and parts. More than likley somebody before you herkey jerkeyed your carbs to the point there at now. It might be as simple as just replacing damaged or wrong parts and get them back to stock. Years back I sent a pair of VS 600 to Biggs performance . Just dont know if theyre still around.
    John Dickey, AED Carbs.
    Quote Originally Posted by flat screwd View Post
    Yeah he is still around.
    LINK: Bigs Performance
    They may actually be a little more receptive to working on a customers carb as opposed to selling a complete carb. There has been some less than stellar feed back on Bigs, and I never heard a bad word about Prosystems.
    But I think either is more than capable of handing a "tune to build" given enough info.
    LINK:GN-RACING.COM
    Abraham Lincoln
