Some Moron
Results 1 to 14 of 31
Some Moron
    Senior Member OLD MAN ON THE LAKE's Avatar
    Phoenix
    Default Some Moron
    Some moron broke off a #8 bolt in my aluminum intake manifold.
    Any tips on drilling it out?
    Carbide bits turn to crap in seconds.
    Senior Member racinjason65's Avatar
    May 2011
    Huntington Beach
    Use an easy out or screw extractor. Otherwise take all the other bolts out and remove the manifold. Then you can grab the exposed threads with vice grips.
    Senior Member jorndy's Avatar
    Sep 2010
    Some Where Between lost and found
    I have used Hanson cobalt reversed twist (left hand rotation) bits with constant flow cutting oil at a slow speed, a lot of times half way through the reverse rotation and heat build-up would back the bolt out. A $200,000.00 Bridgeport comes in real handy for this!!
    Southwest corner AR
    This is a major problem! Grade 8 bolts don't drill well and if it broke on extraction then you have a seized bolt or gaulded threads! It is best to take it off and to a machine shop and have them do it in a mill! If the drill walks any it will only make it worse! JMO!
    What is the bolt used for carb,t stat,dizzy,bracket?
    WT
    WFL Crew!!!
    Phoenix
    Dizzy hold down.
    A mill sounds about right.
    Was hoping not to have to take it off the car.
    ptc
    ptc is offline
    Senior Member ptc's Avatar
    Oct 2010
    Sacramento Area
    JB Weld?
    S.W. PA.
    The reliable way is too use a tap buster that a lot of machine shops have. It is a relatively low cost edm to burn the bolt out. Any edm will work the key word is low cost machine. If it is grade 8 you wont drill it out with anything other than a carbide drill.You have to hold carbide in decent drill press or mill, you CANT do it with a drill motor freehand 'cause it will snap. This is when the edm cost starts to look real good , because you cant drill out a carbide bit with anything.
    Southwest corner AR
    If and when you get it out, use a stud next time! Good luck!
    WT
    WFL Crew!!!
    Peoria, AZ
    Have had a few EDM deals done here in town remove broken bolts out of two of our race blocks over the years. Sounds like a similar moron that did ours.LOL
    Paul
    You must have one of them there big motors. Using a grade 8 bolt for a dist hold down....WOW.
    San Francisco Bay Area
    Cool
    Quote Originally Posted by OLD MAN ON THE LAKE View Post
    • put the bare part on a work bench and have some locking pliers (vise grips) nearby
    • get out your tig and start building up a big mushroom on the end of the broken bolt. As you're doing this, the bolt will begin to turn red and the aluminum will be taking in the heat and slightly expanding from it
    • stop welding, clamp your locking pliers around the big weld-mushroom that you've built up and back the bolt out.
    This is how we get frozen, water-corroded, decades old, seized broken bolts out of aluminum BBF front timing covers. They back right out like they were recently put in....
    High Flow Dynamics
    This post © Copyright 2007-2016 Paul Kane. No copying, linking, printing or otherwise without express written permission.
    Phoenix
    Paul
    Paul, who did you take it to?
    Thanks,
    Tom
    Senior Member Bruise Brothers Dad's Avatar
    Pomona,Ca
    I have always welded a big tit( can I say this Rex) on the end of broken bolts. The heat helps loosen the crud on the threads. Use a Stainless Steel rod 300 series and after welding the big tit on tap it hard with a hammer, this also helps break up the crud. May have to do the process a couple times. While removing the bolt move it back and forth kinda working it loose, just don't try and spin it out unless it's not frozen in the thread. Been doing this ways for 40 years. Good luck... BBD
    Need help finding this 1973 Sanger 18'6" bubble deck mahogany bottom and stringers I was living in Pomona when I sold her in 1979. Just wonder if she still exists
    Update Found my old Sanger 12/7/14 in Reno.
    Peoria, AZ
    Thanks,
    Tom
    I wish I could remember. I think it was down off 48th st. and southern. Buzzz may rememexactlyclty who and were.
    Paul
