do you?
Results 1 to 7 of 7
do you?
    Default do you?
    prop for torque rpm or horsepower rpm?
    Nechako
    more info needed , race , cruise , fishin ? i like an engine to get close to it's peak hp rpm .
    Tower Park Resort, Lodi, CA
    I don't think there's anyone here that wouldn't prop for peak horsepower.
    Not 100% sure, but I think even 50 foot twin diesel cruisers do the same.
    I can't think of doing it any other way unless a huge percentage of running time is at idle and you're trying to tailor it's operating characteristics somehow.
    I think a lot depends on your drive. I do not think you want to turn a Bravo 1 7000 rpm if that is where you make your power. I would keep it under 6000 max myself.
    Nechako
    a lot of people like to overprop on a cruiser thinkin it's more efficient and easier on the engine . hard to get one prop thats going to be the best for everything on the same boat .
    Prop'ing for max torque is great for testing the strength of your entire rotating assembly. Specially the crank.
    LINK:GN-RACING.COM
    Abraham Lincoln
    cfm
    cfm is offline
    Peak hp or just a few hundred rpm under to give you some wiggle room on conditions/passengers/etc.
    Propping for peak tq will usually make the boat a slug and be hard on parts.
