[Question] 502 big block!!!!!
Page 1 of 2 12 LastLast
Results 1 to 14 of 18
502 big block!!!!!
    Jan 2012
    Default 502 big block!!!!!
    Hello,
    I am a car guy and I dont know anything about boats but I have a question I hope you guys can help me out with.
    I picked up a 502ci Big Block 4 bolt main with rectangle port heads casting # 14097088. The guy who built this engine builds racing engines for both drag boats and offshore racing.
    I dont have all the numbers from this engine just yet but what I know so far, it is a full roller engine, Eagle H beam connecting rods, JE pistons, Crane roller lifters, Crane duel valve springs, Aluminum 1.7 rockers, double roller timing chain, Merlin High rise intake, Holly 850 DP carb, Milodon 10 qt oil pan.
    My question,
    When I remove the rear cover for the cam I see a grind number HR 296-2S-12 IG and what looks like "CR" below that.
    When I look this number up I see it is for an engine size of 305-350 ci.... HR- 296- 2S- 12 IG camshaft - Ch. 305 (5.0L)- 350 (5.7L) V8 87- 99
    Why would my 502 Big Block have this cam in it???? Isn't this a tiny cam for a 502 BB?
    What kind of performance can I expect from this setup?
    Thank's for any help here.
    WV
    I would just say you have carryover grind numbers from one to another,definitely not the same cam,
    HR=hydraulic roller, 12 is probaly LSA
    Jan 2012
    Ok,
    Is there another way to find out more info about this cam if were thinking it is just a carry over number?
    Thanks again.
    It's the big block version of that cam. P/N 139641
    Hyd roller
    3000-6500rpm
    296/304 adv. duration
    234/242 @ .05
    .610/.632 lift
    112 LSA
    10.0 - 11.5 compression
    They recommend 120# seat pressure and 410# open with their lifters. I don't think you'll ever see 6500 with those springs and lifters.
    For marine use I'd run a Morel lifter and run at least 160-170 on the seat, and 475-480 open.
    Jan 2012
    Thanks stealcomp,
    That makes more sense. Is this cam any good? Is is considered small or big? Should I junk it?
    This engine is going in a car, is that going to matter?
    Quote Originally Posted by Mike Busutil View Post
    Thanks stealcomp,
    It is not small and not big. It should be a ok cam for a daily driver. I would think it should make a easy 650 hp maybe 700 depending on the combo. Should have a streetable idle and power brakes should still work. If the car is a automatic I would use a 3000-3500 stall conveter. Am I right Steel?
    Thanks stealcomp,
    Good "little" cam for sure. It's fairly large for the street, but not too bad.
    It'll have a rough idle, good mid and upper power. They recommend a 3000rpm converter.
    Are you? You treed me on that one. I guess about 630-640 @ 5800-5900 with those heads.
    I almost did not put 700 hp but thought with good head work, good intake and a good exhaust it might go that high, You are the expert. Right? That is why I would ask you or Straub before I pulled the trigger on buying one.
    Jan 2012
    I was told this engine does have work done to both the heads and exhaust ports...
    That's good because in their stock trim, I'd like to see more ex duration. Engine should run real good if it's put together right.
    Jan 2012
    Update:
    I just found out my engine is a 540 ci. It has a 4.5 Bore and a 4.25 stroke with Eagle crank.
    cfm
    cfm is offline
    Update:
    What's the compression ?
    If 9:1 I'd say 630-650hp with the components listed above. I can't guess on someone else's headwork.
    If 10:1 I'd say 650hp or so.
    A 9:1 502 with same components listed above but with AFR 305 or comparable heads would dyno at 610-620hp at 5700/5800 rpm.
    A 9:1 540 (everything same as 502 just above) will typically see 650hp.
    That cam has been used in kazillions of 502/540 builds for offshore marine engines. Thus knowing the power made by them.
    Jan 2012
    Thanks CFM,I do not know the compression. What is a good way to find out?
