[Question] Input on my build Ford 460??
Results 1 to 14 of 18
    Aug 2009
    Phoenix,AZ
    Default Input on my build Ford 460??
    C8ve heads with ford racing 2.20 intake/1.76 exhaust, ported.
    Ford racing 1.73 rollers
    I'm going to run a Crane Cam #354551
    A pair of 4160 holley 750's.
    Offy Tunnel Ram.
    Probe 2404f-30 pistons, 24.4cc dished
    Eagle 6605Fd Rods.
    Stock Crank ground .10
    D1ve Block, 30 over
    Berkeley 12JG A
    1979 21' Kachina
    Right cam too run??
    Need suggestions on valve springs.....
    Or any other suggestions are appreciated..
    Have all parts, waiting for the block to get out of shop...
    Senior Member nosfomoco's Avatar
    Dec 2009
    Sac, Ca
    Seems like you got a good start. I am no expert but I have built a few BBF's and have tried a few different cams. What are you going to do with the boat? What kind of exhaust? That cam seems a bit small especially if your going to be running two 750dp's. I really like solid rollers on BBF's. I ran a small one with great sucess, but they are pricey. If your going to run headers get a bigger cam(maybe something like this comp cam 34-241-5 )))00000000000099)99 .) I ran this small roller with a tunnel ram and 2- 750Dps Comp Cams 34-700-9 [5] . Hope this helps. I am sure (Lakesonly) or others will chime in with better advice.
    1978 Eliminator Sport Cruiser 20.5ft BBF 460!
    Aug 2009
    Phoenix,AZ
    I'm running bassett through transom headers. The description on this cam (34-241-5) says I need to run headers with it. Also says head modificaion is required..What modification???? So now I need to know what direction to go, do I run the Comp 34-241-5, or do I run the Crane 354551? Suggestions??
    John
    Dec 2009
    Sac, Ca
    Dang nobody else? The head modification is probabley refering to double springs( have to be machined for this) and adjustable valve train( Which I am assuming you already have). I would run anything bigger than the crane. I vote for the Comp Cam . Try this website if nobody else replys 460 Ford Forum
    Anza Valley, Lost Lake, CA
    Quote Originally Posted by lobeeone View Post
    Offy Tunnel Ram.
    Eagle 6605Fd Rods.
    D1ve Block, 30 over
    Berkeley 12JG A
    1979 21' Kachina
    Right cam too run??
    You should run whatever Spring Crane recommends with that Cam................
    As for the rest, what suggestions are you looking for if you already have all these parts???????????
    Aug 2009
    Phoenix,AZ
    Hey nos, I'm going to go ahead and order the cam this week. I talked to Paul (lakesonly) last week, talk about a guy that knows his stuff. The cam subject didn't come up, but I did my research on the cam and am gonna run it, gonna order the whole kit so its all the right parts. I'm on 460.com almost everyday thats where I got all the info on this build, and a few parts.
    Turtle, yeah I have 99% of the parts just making sure I was running the right combo, thanks for suggestions and opinions.
    John
    Jan 2011
    Mickleton, New Jersey
    Offy Tunnel Ram.
    Eagle 6605Fd Rods.
    D1ve Block, 30 over
    Berkeley 12JG A
    1979 21' Kachina
    Right cam too run??
    Now much HP do you think it will make, I love to hear these answers..
    Aug 2009
    Phoenix,AZ
    Aug 2009
    Phoenix,AZ
    Sound about right Jim?
    Jan 2011
    sound about right jim?
    maybe a little more than that, I don't know much about that camshaft????
    Senior Member racer's Avatar
    Dec 2010
    if you get it all right it should be somewere in the mid 500s.... depends on ports,ignition type,how good the carbs are? and timing/quality of the build/machine work and getting the cam in the right spot..
    Dec 2009
    Sac, Ca
    Ran it on Desktop Dyno just for fun. I used my flow numbers on my Ported C8VEs with 2.19, 1.76 valves. The first one is with the Crane Cam. the second one is with a Torque monster Small Solid Roller Comp 280AR-10
Name:	Mild Marine 460.jpg
ID:	148234   Click image for larger version.
Name:	Mild Marine 460 With small roller cam.jpg
    Aug 2009
    Phoenix,AZ
    hey nos what are the chances of you running one with the xm278?
    Jan 2011
    Quote Originally Posted by racer View Post
    THATS GOOD FOR STARTERS I would have liked to see the compression a little higher
