I have a tuning idea and want opinions
Page 1 of 2 12 LastLast
Results 1 to 14 of 18
    Chico, Ca
    Default I have a tuning idea and want opinions
    I picked up an LM1 hand held o2 sensor/monitor a little while ago. Most of you know I'm an efi guy to the core and all my stuff and customer stuff have o2 sensors in the cars/boats all the time. So I was thinking while reading Master Sergeant's post that maybe I should see if I can get some decent OT BBC headers and put o2 bungs in both sides and rent out the setup to you carb guys as needed. Would there be interest in this? I'm not looking to make money on this or anything, just want you carb guys to feel as spoiled as us efi guys. I would require at least a deposit to ensure I get the stuff back, and maybe a small fee for any maintenance needed or o2 replacement, crap like that. I know plenty of you are up in northern calif. like myself, but I'd even ship if someone really didn't want to purchase an o2 (probably be almost as expensive to ship as just buying). Is this something that would get used? I don't want to search for a set of OT headers if this isn't even an interest for people.
    Let me know,
    Andrew
    Let me know,
    Andrew
    It's kind of a cool idea, but you won't have a lot of control over how it's used,, and may not find out that a sensor is bad until it goes to the next guy?
    I ended up with one tuning a carbureted Whipple engine, thought it would get more use than it does, even set up the dirt track car with a bung in the headers but would have needed to rig a mount and have a laptop to play it back since it would have been pretty impossible for him to drive the car with one hand and read the meter in the other hand...
    Chico, Ca
    I think people would need to know that this is a setup for helping with fixing tuning problems, or dialing in WOT, not necessarily for fine tuning every aspect of the power band. I would suggest use with a friend, and hope it would be treated as their own. It's an older unit and I typically have 3-4 o2 sensors here at the shop, so hopefully a small fee would cover those issues that might arise. Plus this would be a dry header setup. Blue the crap out of the loaner headers, get the tune pretty good and put the pretty water injected back on, which hopefully would improve o2 life. No doubt there may be issues, and if it becomes a problem I'll just stop doing it, but it could be helpful to some I'd think. That's why I thought I'd ask.
    Andrew
    Hey,, you know me,, just playing devil's advocate. It's actually pretty cool of you!
    Salem,Or
    My Lightning headers have the o2 bungs in them, I have always wanted to try that out
    With Spray there is a way!!!
    Lake Havasu az.
    I was wondering if the o2 sensor would work if it was sunk in the intake manifold in the exhaust x-over?
    Sheriff Joe Arpaio
    Ada, Michigan
    I've lent out the LM-1 I had a couple times.
    Both individuals took good care of it and the 2nd guy bought it.
    After someone has used one they are hooked. All the guesswork is removed.
    okie, lake Texoma
    I am the one that barrowed Marks LM1 and then I purchased an LM2. The main problem I see is depending on who the guy is borrowing this and what kind of rig they are trying to tune they might have to have the datalogging feature. If the boat is fast things happen so fast you cant keep an eye on it even if its right in front of you. The LM2 will play back logs of the A/F right on screen but you will need to pull the sd card and use a computer to overlay rpm-a/f-and anything else your logging. It will log 6 sensors total.
    You can tune idle & cruise easy with the lm1, and if you can hold the boat wfo for 6-8 sec at a time while looking directly at the lm1, or having a passenger do it, you can get pretty close at wfo but still not as good as logging. And for some reason I could never get anyone to ride with me & keep their eye on the lm1
    H8-2-W8
    5.89@139.4 first pass
    Placentia, CA
    In the pic below, my son Ron is holding and reading an LM 2.
Name:	Needles 1_0001.jpg
    steveo143 AKA DiMarco 21 II
    Chico, Ca
    Hass, I would say you're at a power level and engine setup that warrants you buying your own....which you did. You need data logging and you benefit from multiple input streams. If this is something that would happen I see it going to people where their biggest concern was getting an o2 bung in their headers. Not, "who is crazy enough to get in my boat and read the screen?" maybe its just not something that the mild hotrod lake boat guys want to deal with?
    Andrew
    Administrator Infomaniac's Avatar
    Locust Grove, OK
    What about a spacer between the head and header? Wouldnt have to be very thick if small tubes ran up to a sensor bung. Still might be able to use wet headers that way.
    QE 439 Twin Turbo
    okie, lake Texoma
    Andrew
    I agree, and for the average jet boat guy what you are offering would be a great idea. I see most guys with the average jet boat running around dont know anything about their tune except that it gets them to out on the lake & back. Would be a great idea to install to correct the tune & then return to you. Most will want one of their own after trying it though.
    H8-2-W8
    Chico, Ca
    Exactly, I just don't know if it's something that those guys think they need. I've met many people who think they have dialed in a tune by feel.
    Chico, Ca
    That might work, honestly though my first thought is that I'd have to make something like that which isn't very appealing. if the demand were high enough then maybe it'd be worth it. (be easier to ship, that's for sure).
