NA, 088, 496, Plug Recommendation?
Results 1 to 6 of 6
    Senior Member Constant840's Avatar
    Yucaipa, Ca
    Default NA, 088, 496, Plug Recommendation?
    As the title states... I am looking for a spark plug recommendation for a NA, iron headed 496.
    Currently running cold (nitrous) Autolite AR13's and know it should be warmer.
    Suggestions are appreciated.
    "Evolution has long been the target of illogical arguments that use presumption." - Marilyn vos Savant
    I think you are going to need to give alot more info, IE. what comp ratio,are you running the nitrous or not. what do run the timing at? do you run a timing retard if you are running nitrous? how much nos. what kind of dist you running msd or mag system. what fuel are you running ?
    whats going on with the plugs that you have tried and what do they look like?
    The more info you give the better a shot at getting good info back to you.
    Yucaipa, Ca
    Quote Originally Posted by havasubyou View Post
    9.3-1
    No Nitrous
    32 degrees
    MSD 6 with Pro Billet
    Pump 91
    Current plugs were hand me down from a blown 468 running a 200 shot. I can not find the plugs that were run in the 496, while it was a 454, so I do not have a baseline idea of what plug to start with.
    Oct 2011
    UR-5 ngk
    Nechako
    i wouldn't want any hotter than a 6 ngk
    Quote Originally Posted by Constant840 View Post
    Jason,, did some reading on Autolite racing plugs just now,, AR13 is only one step colder than the 23 I mentioned to you on the phone. You can probably run more than 32 degrees of timing, maybe try 34 or 36 degrees I think.
