[Question] 454 5140 crankshaft
Results 1 to 9 of 9
454 5140 crankshaft
    Mar 2011
    Default 454 5140 crankshaft
    i have a question about a crank. i'm building a 100 over 454 chevy for my sanger ski hydro. my target hp is about 700. i have a nos forged 5140 crank part #3963524. i was told this crank will not support that kind of hp. what do you guys think? thanks, bill
    Senior Member PCE680's Avatar
    Manhattan Beach,CA / LHC,AZ
    It will work just fine.
    Quote Originally Posted by PCE680 View Post
    X2. IMO the only real drawback with the OEM crank is the external balance.
    Senior Member ohflat's Avatar
    Nov 2008
    Default motor
    mine is 100 over but internal bal very snappy
    Gone
    Sparks, Nevada
    Better be sure it is straight.
    Feb 2012
    Sacramento ca
    That crank will be fine make sure to have it checked for cracks and straiteness mines was bent .003 had it straiten and make sure you have a good balence job I had one in a 477 cu 14.2.1 comp motor turned it 7600 and held up
    Mar 2011
    Default 454 crankshaft
    thanks for your help. many people think its ok. i think he wants to sell me new parts. going to look for a new machine shop.
    I`m no expert by any means however I had my .030 454 block split a sleeve and trashed the whole motor...I know some people that have done that .100 over and never had a problem me I dont have that luck
    Quote Originally Posted by tkriley13 View Post
    I'd blame the sleeve. I no fan of .100 over BBC blocks. But you should have no problems with a sleeve at .030 unless your pushing some serious NOS.
    LINK:GN-RACING.COM
    Abraham Lincoln
