460 over heating
Results 1 to 5 of 5
460 over heating
    Member wheelman's Avatar
    Feb 2010
    pontiac MI
    Default 460 over heating
    I have a 1977 weirdt with a 460 and a Berkeley pump. When i got picked it up it had water logs one it. I only drove it a few times and everything seem to work good. It came with bassett headers so i installed them and hooked the water lines up the way they said. Well the next time i took it out. It over heated and threw a rod. I pulled the motor and installed a different 460 but it still over heating. I checked the hoses and they are not plugged i ran water out the pump to make sure the wear ring didn't spin. I am going to put the water logs back on but i cant see how that will make a different.
    This is my first jet boat and i cant seem to figure it out.
    Thanks Leroy
    corona calif
    Default Over heating
    Quote Originally Posted by wheelman View Post
    Thanks Leroy
    Leroy, Can you explain to me how you have the engine plumbed? It really should make no difference which exhaust you run in respect to overheating.
    Feb 2010
    pontiac MI
    Off the jet splits and runs in both sides of the water pump plate then out the thermostat housing one line runs over board with a ball valve the other runs to the bassett tee then to the headers.
    corona calif
    Default 460 Ford
    Do you know the history of boat. Where was it run , on the lake in deep water, or on the river in shallow water. Has the pump been making any wierd noise's,like a bearing whine? Take the boat back to the water and disconnet the dump lines on the thermo. housing and see if you are getting good flow thru the engine.
    Senior Member md-11mike's Avatar
    May 2012
    Thousand Oaks Ca
    Post up several pictures of how you have it plummed.
